Results 1 to 16 of 16
Thread: duck poop?
    Oct 2015
    North Texas
    23
    duck poop?
    I found my pool with a whole bunch of dark debris in the bottom, quite a bit of which is now smeared into the plaster. How would I know if it was duck poop? The only other thing I can think of would be some punk kids throwing dirt/mud over the wall into the pool. So my questions are...
    1) how do I know if it is duck poop?
    2) how do I remove the smears off the plaster? It looks awful, and brushing isn't helping.
    3) I'm assuming I need to SLAM?
    Any advice would be greatly appreciated!
    13.5K gallon, freeform gunite pool, quartzscapes Aruba Sky plaster w/ flagstone, Hayward Swimclear C4030 cartridge filter, dual speed pump, pool build completed 6/23/16, TF100, Hayward T-Cell 9 SWG, Prologic automation, spill over spa
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    536
    Re: duck poop?
    Quote Originally Posted by kmom View Post
    1) Duck poop looks dark greenish to an almost black tint..
    2)I cannot help you there.. I have a vinyl liner..someone will come along shortly and answer that.
    3)This has happened to me often.. and I always like to SLAM after just to be sure..
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    Oct 2015
    North Texas
    23
    Re: duck poop?
    Quote Originally Posted by TSiGirl View Post
    Hmmm...then maybe it isn't duck poop after all. This stuff does not have any tint of green. It is definitely dark brown.
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    392
    Re: duck poop?
    I had what I thought was raccoon poop in my pool last year. I was able to brush the stuff off and it was filtered out. I did however raise my chlorine up to the SLAM level for a couple of days and cleaned my cartridge filter. I googled "raccoon poop in pool" and was able to find pictures that helped me identify the material. I also know that we have raccoons in the area and there was a bunch of water around my pool steps so this led me to believe it was raccoons. I would think that if what you had was duck poop that it would eventually soften and you would be able to brush it away. I would definitely raise your chlorine level just to be safe.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence t-9 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    Mar 2016
    Port Orange, FL
    392
    Re: duck poop?
    This is a pic of the raccoon poop in my pool.
    Oct 2015
    North Texas
    23
    Re: duck poop?
    Just a couple of the spots.
    This was the only spot on the coping. Everything else was in the bottom of the pool.
    I will post a new picture of the stuff that is still stuck to the plaster when I get home.
    Mar 2016
    Port Orange, FL
    392
    Re: duck poop?
    That's quite a bit of whatever it is. Do you have ducks close to where you live? Is the material dissolving at all? When it comes down to it, it might not matter so much what it is, I think I would still treat it as some kind of animal poop. Get as much out of the pool as you can, run the filter for at least 24 hours and increase the chlorine level for a couple days.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: duck poop?
    Raise FC to shock level, FC/CYA Chart, and brush often for a few days to a week. That should take care of whatever it is and the stains.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Re: duck poop?
    There's only one way to be sure...
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    Re: duck poop?
    This happens to me most of the swim season. As pooldv says, raising FC and brushing will help. I've learned to live with it. It fades away in a couple of weeks.
    In my case it's frog poop. I've gone out in the middle of the night, turned on the light and interrupted their party on a few occasions.
    I ignore it now. I used to scoop them out, but I have figured the little buggers can get out on their own. The only thing I scoop out now are the small snakes that wander in at times....
    Support the site
    Apr 2017
    Maine
    231
    Re: duck poop?
    Any grackles near you? Mid size black bird? Grackles remove all waste from their nests to avoid predation. These European birds that were imported to help with pests in farms grew up on cliffs near.....Yep, water. So they follow instincts and drop it in pools. Gross.
    Oct 2015
    North Texas
    23
    Re: duck poop?
    Quote Originally Posted by Chemnut View Post
    Definitely could be grackles. The store parking lots here are overrun with them. I will have to keep an eye out for that.
    Dec 2016
    Arlington, Texas
    291
    Re: duck poop?
    Yup, grackles are horrible around here
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    Re: duck poop?
    That is grackle poop. It is nesting time right now. Search grackles in the forum for possible fixes. I am using an inflatable alligator this season and so far they are going and doing their business in the neighbors pool. It will go on for another month.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Apr 2017
    Maine
    231
    Re: duck poop?
    Actually, grackles can have two breeding seasons. Gods version of a flying rabbit hint hint
    Oct 2015
    North Texas
    23
    Re: duck poop?
    Grackles definitely make more sense. This is our first spring with a pool, so this was a first for me. I raised the FC to shock level and I will keep brushing at the stains that were smeared. I will probably go buy myself an alligator, lol. Thanks for the help in figuring this out!
