Results 1 to 7 of 7
Thread: Is it OK to drain your pool into a lake?
    Apr 2017
    Greensboro, NC
    189
    Hello all,
    I recently acquired a house with a pool -- IG, vinyl, roughly 22,000 gallons. Pool is about 10 years old and (supposedly, according to the previous homeowner's pool guy) will need a liner in the next season or two. With the age of the pool I'm not surprised.
    Just out of curiosity, is it OK to drain the pool into a local pond/lake? There's a 2-acre pond about 200ft behind my house. Seems like it would be an optimal place to drain the pool when it's eventually time to replace the liner.
    I'm on well water with a septic system so I don't have a municipal supply I can drain it into.
    Thanks!
    20k gallon, in-ground, vinyl liner, well water
    Hayward S200 sand filter, Hayward SP2607 1HP pump, Hayward HP21002 heat-pump
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,267
    Re: Is it OK to drain your pool into a lake?
    There may be chemicals in your pool that would be harmful to the wildlife and plant life in a lake.
    Apr 2017
    Greensboro, NC
    189
    Perfect! There's a ton of Canada geese that live on the lake that are loud, obnoxious, and poop everywhere.
    AND if I kill all the fish in the lake there won't be any reason for my brother-in-law to come over and go fishing! Double win!!
    May 2016
    West Bloomfield, MI
    756
    I live on a 5 acre pond. When my pool was drained for resurfacing, I drained as much as I could into the sewer, but most of it had to go outside. I dropped the CL levels as much as I could beforehand, but even so, later that day the corner of the pond closest to the pool water showed less algae than normal!
    Unfortunately, it didn't deter any Canada Geese. It may have attracted the dang things, which honk back at me when I chase them from my yard.
    Unrelated side-note: I regularly enjoy watching a couple of huge swans bully the geese. I had company over the wkd, and they explained to me that the swans are invasive. These orange-billed "Mute Swans" were imported. The native Trumpeter Swans are all but gone.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    triptyx's Avatar
    Apr 2016
    1,475
    Probably not, but you'd be best calling your local water department to find out what the rules are for swimming pool water discharge. I couldn't find anything online, but that doesn't mean they don't have ordinances and huge fines for sending your pool water to the wrong place.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2016
    West Bloomfield, MI
    756
    When I googled it, nearly every article mentioned reducing or eliminating CL first. They also like to see pH on the higher side.
    Donldson's Avatar
    NW Ohio
    3,211
    At the very least I would neutralize the chlorine, or allow it to drop to undetectable levels. It also depends on whether the pond is owned by anyone since you could run in to some trouble if you dump your water in to someone's pond without their permission.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
