Thread: Use of main drain to control flow
    Mattsway's Avatar
    Apr 2017
    Sussex UK
    30
    Hi, I'm running my pump 24/7 during my first SLAM and all is moving in the right direction.
    The problem is, I have a small suction leak and am spending ages bleeding the air, especially in the morning.
    I have slowed the leak by only using the main drain to the pump, so the skimmer valve is closed because that's where most of the air was leaking in.
    Can I further slow the leak by partially closing the main drain? Would doing that make a difference, or would the reduced pressure reduce the efficiency of the bleeding?
    My pump is oversized by design to give the fast turnover that might be needed in a hydrotherapy pool used by my disabled son. I was thinking that I could reduce the flow rate now there is a zero bather load. The usual pressure at the filter is 16psi.
    The suction pipework is inaccessible to me and the builders aren't available to fix it for a while, which is no problem with usual use of the pump of max 3hours a day, needing only 1/2 hour bleeding.
    In ground hydrotherapy pool in wooden cabin. Oil heater for water temp 89f. Poly Bloc construction using high temp liner. 9'9" square x 3'8" deep, 2700 gallons. Hayward MaxFlo XL pump, model SP2310XE161 0.97hp. Waterco Multicyclone 12 Plus Centrifugal Filter, guage reads 16psi. Certikin Skimmer with floating collar Weir. Spectrum UV light, Calorex 33 dehumidifier and 2 radiators in cabin. Taylor K2006C test kit.
    Mattsway's Avatar
    Apr 2017
    Sussex UK
    30
    Re: Use of main drain to control flow
    Related to the above, do I need to have the pump running 24/7 during the SLAM given that the water is clear? Once the chlorine is mixed in after a full turnover, does it need constant circulation to react with the organisms in the water? Just a newbie's brain ticking over...Possibly completely wrong.
    30,961
    Keep your pump running until you complete the SLAM.
    Is the water level in the pool high enough to keep the skimmer(s) from sucking air? Why do you think it is the underground pipe from the skimmers causing the air intake?......it rarely is the cause.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    It is generally best not to try to choke the flow down on the suction side of the pump. There is risk of cavitation and pump damage
    Mattsway's Avatar
    Apr 2017
    Sussex UK
    30
    Please see my last post for the suspected cause;
    Air in pump when heating on?
    Water level is half way up the skimmer. I have lubed all o rings and run water over the pump lid and suction pipework without success. I also tried cling film and smoke to check for air getting sucked in. Shutting off the skimmer line slowed the rate at which the pump sucked air. The suction pipework at the skimmer end is under plywood, the top of which is covered by the vinyl covering the pool.
    Quote Originally Posted by pooldv View Post
    Thanks for this. I'll leave it fully open.
