I recently installed a new Hayward MaxFlo 2303VS pump about a week ago on my above ground pool. Pump was performing perfect the first week after installation.
I had installed a 240v 15amp 2 pole GFCI breaker. Since the MaxFlo does not have a neutral at the pump, the GFCI breaker at the panel does not utilize the neutral, the white pig tail goes to ground.
After 2 days of heavy rain (around 5" or better) my pump stopped working. I went out to the panel and the GFCI breaker was popped and would not allow for a reset - not even for a fraction of a second. I don't get that hard click like you get when locks into the on position. Once I let go it just moves back to middle position. I do get a click when I move it to reset (left) but still wont stay on when I move it right, it just goes back to middle when I let it go.
The next day (yesterday) after the rain stopped I went under the deck and removed the watertight cover to the electrical connection on the pump housing and found it full of water. (This is the area where the electrical leads are connected) I found the leaky culprit and corrected it and after drying everything out for a couple of hours I still cannot get the breaker to reset. Its still behaving as described above.
Could I have damaged the pump circuit board or is it possible the GFCI breaker went bad? Another question is could the water have gotten deeper into the pump behind the lead (watertight) housing?
I have another 2 pole 15 amp (non GFCI) breaker I am thinking of swapping out with the non resetting GFCI just to test and see if it is the breaker but don't know if this could damage the pump if the problem is elsewhere. Or should I let the pump dry out for a day or two before trying this.
