Results 1 to 8 of 8
Thread: CYA levels and FC
    Apr 2015
    Waikoloa Hawaii
    13
    CYA levels and FC
    I'm about to get very unpopular. I'm picturing folks driving around, listening to their 8-tracks in their AMC Gremlins, imagining how perfect 80 ppm CYA is . Folks, come into the new century already (I'll explain after I get flamed)
    Apr 2015
    Waikoloa Hawaii
    13
    Re: CYA levels and FC
    Amg.....1.5 FC @ 7.4 pH & 15 CYA is doing significantly more work sanitizing your pool than 5 FC @ 7.6 @ 80 CYA ( unless someone really wants to put forth the argument that the hypochlorite ion is an effective sanitizer/oxidizer)
    Mod note: poster is recommending a CYA level of 15 during summer in a pool in Phoenix, AZ. Posts moved to Agree to Disagree for further discussion with anyone who is interested. pooldv
    Apr 2015
    Waikoloa Hawaii
    13
    Re: Hayward salt and swim only make 1.5ppm FC
    Apr 2015
    Waikoloa Hawaii
    13
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    What we teach at TFP is based on the science learned and taught by Ben Powell and Richard Faulk, cited in the article in Aqua Magazine. Credit is given to them at the bottom of this page, FC/CYA Chart. This is also where we recommend CYA levels of 70-80 for saltwater pools.
    Jun 2013
    Augusta, GA
    90
    I am no expert, but it seems that the articles you posted reinforce what is taught on this forum. You may be correct that your 1.5ppm FC@ 15ppm CYA is "doing more work", but the issue is trying to maintain that 1.5 ppm effectively with normal bather load and sunlight. Also, with your recommended level of 15ppm CYA, you will more than likely use a higher amount of chlorine to maintain your 1.5ppm FC, and you are also at risk of wide FC swings, as a percentage of FC. The CYA levels recommended on this site buffer against wide swings in FC, and allow for greater accuracy when testing and dosing for FC, when using convenient and affordable testing and dosing methods.
    Your response, OP?
    30'x52'' AGP 21,000 Gallons
    TWM 2.64 SF Sand Filter w/ Century 1.5 HP Pump
    BBB'er for life!
    TF-100 Test Kit
    Donldson's Avatar
    NW Ohio
    3,220
    Um, pools didn't use stabilized chlorine in the early 70's. That would be the time when 8-tracks we're popular. Gremlins never were all that popular though, we really just remember them because of the name.
    Just as well since you are posting articles that were based on the work of the forefathers of TFPC. Seems you are a bit confused all around. Perhaps if you try asking questions in a less aggressive (and ill informed about the 70's) way you could start a constructive dialogue?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    30,961
    HawaiiPoolGuy,
    Your posts make no sense. Richard Falk was instrumental in developing the methods and chemistry we teach. Yet, you quote him as if we don't know anything about what he is saying.
    Either you simply didn't bother to read the links you posted or you have some other agenda........can you help us understand?
    A note of caution.....we are a teaching forum.....not an arguing forum. If you are here to argue the chemistry or the methods, you will have to find another forum. If you are here to learn what we are saying and make contributions to say it even better, you are welcome
