Thread: 1st time testser
    IMason's Avatar
    Sep 2016
    Clayton/CA
    40
    1st time testser
    Ok, so I got my Taylor k-2006 kit and just tested my water. of note, the PB has put salt in it but doesn't seem to have turned the SWG on (so that's another question).
    FC= 2.5
    CC =0
    pH= 7.0 (!)
    TA= 50
    CYA = 42
    looks like my CYA and FC are too low as is my pH. what to do?
    17K gallon, inground, gunnite, stonescapes tropics blue puerto rico blend pebble, above ground spa with spill , Jandy VS 2.0 hp pump, Jandy cartirdge filter, Jandy pool & Spa heater, Jandy SWG, Aqualink automation, Taylor K-2006
    30,944
    Re: 1st time testser
    I would raise the FC to around 4-6 ppm. 2.5 is not adequate
    I would also leave pH and CYA alone for now. pH will naturally rise
    CYA is not bad so don't be in a rush. Do your summer temps get into 90+?
    IMason's Avatar
    Sep 2016
    Clayton/CA
    40
    Yes we get well above 90.
    To raise my FC can I just turn on my swg and keep testing?
    Dec 2016
    Arlington, Texas
    291
    What does your PB say about turning on your SWG? How long ago was the salt added and have you run your pump at least 24 hours straight since then? Bleach would be the best to raise FC. A SWG is best at maintaining a level, not raising the level
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    IMason's Avatar
    Sep 2016
    Clayton/CA
    40
    There was a bit of miscommunication with PB. He put in salt last week but then didn't tell me what to do...
    I will look tonight to see how I even turn it on.
    Will likely have to put in some bleach then.
