Thread: Grout repair FYI
    Mar 2017
    El Paso texas
    13
    Grout repair FYI
    I just used a pool patch grout repair kit to fix some tile where the grout had come off. There seem to be different versions but I think they are the same, just some white cement with a bonding additive.
    Anywho a word to anyone looking to use it, this stuff drys quickly! I mean don't use the whole three pounds at once if you're not prepared to moved quickly before it starts to dry out. I've tiled floors before so I know how to grout.
    I divided up the container into 4 equal parts and measured the additive into the same amount. I then decided what four sections of the tile to fix and worked in sections and it worked well this way. Anyway just throwing this out as an FYI hope it helps.
    Gunite pool
    12000 gal.
    Pentair sand filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Grout repair FYI
    Thanks for the info!
    Essential Links:
    Jul 2016
    Salina, KS
    54
    I have some spots in my grout that seem to be eroding a bit. How do you clean existing grout out before you re-grout?
    Kevin
    IG Tile/Concrete Pool - 12,000 gal or so, Targus Sand Filter, Pentair single speed pump
    IG Tile/Concrete Spa
    Mar 2017
    El Paso texas
    13
    Quote Originally Posted by bigkevj View Post
    I already had a couple of tools to scrape out grout, one has carbide and the other is a blade with some hooks. You can find them at Home Depot or Lowes.
    You could also use a fine bladed screw driver or a utility knife. My tile has thin joints so sometimes the tools were a little too wide and the knife worked better. Afterwards a good power wash will clean everything out and may even expose some other loose grout, happened to me. Hope this helps.
    Gunite pool
    12000 gal.
    Pentair sand filter
    GoGrabTheNet's Avatar
    Dec 2015
    Phoenix, AZ
    65
    Quote Originally Posted by Robord View Post
    I just used a pool patch grout repair kit to fix some tile where the grout had come off. ...Anywho a word to anyone looking to use it, this stuff drys quickly!
    Product?
    13k Gal. PebbleTec IG pool : Pentair IntelliFlo VS pump : Hayward 8-cartridge filter system : A&A in-floor cleaners : Jandy 115k BTU heat-pump : A&A auto-filler : Stenner 45MPHP10 auto-chlorine feeder : BBB Method
