Thread: Hairline cracks!
    Mar 2017
    El Paso texas
    13
    Hairline cracks!
    I drained my pool in order or remove some heavy scale from the tile, do an acid wash and fix some loose grout. What should have taken a week turned into 3 weeks with unforeseen delays slowing everything down.
    Be that as it may I'm done and refilling the pool. Problem is I'm seeing hairline cracks as the plaster is getting wet! Not one or two but the whole pool! Looks like a spider web. Outside of this there are no major cracks. There's no water table here that would have pushed the pool up so I'm wondering if these developed due to the plaster being dry for so long.
    The only thing I can do is fill it and watch the water level. If the damage is done it is what it is, hate to have to replaster the pool. A friend said to go ahead and paint the inside, the paint would seal the cracks but I would just be hiding the cracks.
    Anyway looking for input to see if anyone has come across the same thing. Thanks for looking.
    Gunite pool
    12000 gal.
    Pentair sand filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Hairline cracks!
    It sounds like it is from the plaster drying out and the cracks should close back up as the plaster rehydrates.
