Thread: concrete or dirt ?????
    Apr 2017
    buena vista va
    14
    My perimeter for my 18ft AGP is spot on ready for the patio block and bottom rail BUT I noticed this evening after 4 inches of rain the past 2 days that 2 areas in the inner of the circle, roughly 2x2ft are holding a puddle, maybe a inch or so deep. Should I fill these with concrete or maybe dirt ? I will be using foam for the bottom and foam cove. Suggestions ????
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: concrete or dirt ?????
    I would use sand, which is what would normally fill in those gaps before people started using foam. You definitely wouldn't want to use concrete that would just make an awful mess.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
