Thread: Quick Backwashing Question
    Nov 2014
    Alabama
    4
    Post Quick Backwashing Question
    I have a two speed pump on my 27' AGP and was wondering what speed ya'll set your pump at when backwashing? I see posts where I should be backwashing for like 3 minutes and wasn't sure if that was on high or low.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,606
    Re: Quick Backwashing Question
    You would want that on high for effective back washing.
    Then rinse for 30 seconds. (make sure pump is off when switching multiport.)
    Dolphin E10 Cleaning Robot.
    Nov 2014
    Alabama
    4
    Awesome thanks! I was afraid I'd be wasting water by backwashing on high for that long.
    Belo's Avatar
    Jun 2013
    Rochester, NY
    33
    just a note. you may want to refer to the size of your pool in gallons, not feet. Helps
    24,000 gallons, IG, vinyl
    Pump: dyna-tech 1hp
    Filter: Hayward S210T w/ variflow xl
    brominator: perform-max pool sanitizer
    May 2016
    West Bloomfield, MI
    756
    I run the stopwatch app on my phone while I backwash, but really only for reference and rinsing. The color/purity of the discharged water dictates how long I backflush. The last time I backwashed was the first time after adding DE. The water ran dirty for almost 4 minutes IIRC.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
