Results 1 to 13 of 13
Thread: Liner replacement ??
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    So, we know we need to replace the liner.
    A) it's over 12 years old
    B) it's is coming out from the top (could be stretched possibly)
    C) there are quite a few small rips
    D) liner is no longer blue, it is whitish
    Just got a quote and hoping someone can help me know if it is decent.
    This company actually pumps the current pool water into a container so no need to refill
    I attached the quote. But it is $4,195.00 for liner replacement.
    Liners come from either looploc.com or garrettliners.com
    We are in Massachusetts, do will a20 mil liner be sufficient?
    In ground Liner, MBP-125A Heat Pump by Aqua Heat , built 2003, 18x37 Grecian style, System 3 sta-rite filter. @22,000 gal, tftestkits TF-100 & 1766, USQ1102pump installed 6/2016, new liner installed 07/2017. Circupool SJ40 SWG (7/2018), Dolphin S300i 7/2016
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    Re: Liner replacement ??
    That seems high, unless they are custom measuring it to make one.
    Mine cost a few hundred less than that and they did have to custom measure
    because the previous home owner didn't have the serial number of the liner
    and it could not be found on the old liner.
    Do you have a serial number?
    Dolphin E10 Cleaning Robot.
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    We do have a serial#. We also have the actual blue print of the pool design...
    They are saving the water, replacing the foam, maybe I should get a quote for the liner itself as I'm looking online the liners are about$1000
    30,964
    Yeah, get another price. I seldom comment on pricing but that is too high.
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    Thanks - your input is greatly appreciated!!!
    Aug 2016
    Pittsburgh PA
    345
    Didn't know they actually saved water to reuse. I guess they pump it into water trucks. Is that cheaper than discharging and rebalencing?
    18'x36' vinyl - 24k gal - Intelliflo 3hp VSP - Pentair C&C 420 cartridge filter - IC40 Salt - EasyTouch 8 - ScreenLogic - Raypak 406btu NG heater - Intellibrite 5G ligths - 4 deck jets - sheer descent - X-Stream Slide 2 - TF100 kit - opened spring 2017
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    This company actually pumps it into these military grade bladders. It saves a ton of money and water. Water is not cheap here since we are still in drought.
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    Just got a second quote (from the company that installed the pool originally):
    $4,900 plus water replacement as they just drain it and if we want 27 mil, it is an extra 15%.
    They say things in Massachusetts are more expensive than other states, maybe it's true for this as well.
    To open the pool last year- literally just taking off cover, dropping in the chemicals I bought, taking it the plugs, putting in ladder (no testing of water, and it was green) they charged$425!!
    Nectarologist's Avatar
    Apr 2015
    New York
    471
    I'm close to NY so very similar prices to the Boston area. That is what I've heard in my neck of the woods too for a new liner (similar to your first quote). It's easy to get a third quote though since you have the specs. I like that they reuse the water, had not heard of that. Let us know what liner you choose. It's exciting since most people will only change their liner a few times during the life of the pool.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Feb 2016
    Southern NJ
    22
    The pool opening sounds high. In NJ they are no more than $200.
    New construction- April 2016
    1st time inground pool owners. 20x40 oasis shaped vinyl liner. Gli gerano 28 mil liner. Sr smith typhoon slide. Pentair 5g color changing light.
    waterl0gged's Avatar
    May 2014
    Central PA
    128
    We are having our 18' x 36' liner replaced in the upcoming weeks. I have estimates that range from $3200 - $3500.
    Narrowed it down to a very highly recommend smaller local pool co. who has done many liners in our area for about 25 years . Have seen many install photos from them and offered referrals if we wanted (we already had some from friends) . Was able to see their own actual real pictures of many liner installs , and many in our desired liner choices, so we know they do a LOT of liners . They all look great, and the company is known for being perfectionists ! They happen to be the higher $3500. estimate .
    The pool Comp is supposed to be here today to drain pool down to get accurate custom measurements tomorrow (they are perfectionists , and will not just guess on those measurements). All of their liner jobs fit perfect, so I feel very confident with their process .
    Their $3500. estimate / price including everything except about 2 truckloads of water (the rest I can fill with our hose well water ) .
    That includes all labor for removal of old liner and disposal , preparing/patching smoothing out the old surface / bottom of pool , fixing any irregularities in the side walls (luckily we have fiberglass sides, so there wont be any rust issues) , deleting the old underwater pool light niche area , and full install of a new 28mil liner (they use McEwen industries liners) , including return faceplates and such . Only other cost will be approx 2 truckloads of water so they have enough to fit the pool liner into place properly while using the vacuum/blower technique as well .
    Also, we pay the water truck co. of our own choosing , the pool co. does not make extra $$$ on the water fill .
    We should be roughly $4000 - $4200 by the time its installed including a bulk of the water . This will be with a 28 mil liner, but also including whatever it takes to delete and cover up the old underwater pool light niche area (we dont need or want that anymore) .
    I think your first estimate is not out of the ballpark , maybe a tad high with only a 20mil liner installed, and not a lot of extra work required (like our light niche delete).
    Do you trust this company, and do they do GOOD work ?
    If so, a few hundred bucks is well worth it over a cheaper estimate from a company that might do less than a perfect job .
    Thats why we are going with a slightly higher priced Pool co .
    Something to think about ............
    EDIT : Our choice of Pool Co. , after a more thorough quote and inspection of our pool, LOWERED their estimate of $3,500 to $3,300 !!! WooHoo !!!
    18' x 36 ' - 8' deep end. In-ground, McEwen "Pence" vinyl liner .
    Blue 8 Mil. Solar cover & roller . Pentair Superflo VS pump . Poolskim .
    Hayward S210 Sand Filter . Heat Siphon Z575HP heat pump pool heater .
    Stenner EconT / Liquidator Hybrid : running 10 % bleach . Dolphin S300 Robot .
    TF100 Test Kit w/ Speed Stir for the 25,000G pool and 400G Hot tub .
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    507
    Quote Originally Posted by PureLuck View Post
    Sent from my Moto G (4) using Tapatalk
    I have my local pool company out today to open the pool. They charge ~$365, but they take the cover off, put all the fittings back, vacuum the pool, skim, add chemicals, get everything up and running, and power wash the pool deck. They even drained the spa, power washed it, and then sucked all the dirt out with a shop vac before refilling it. Oh - and they added 25 lbs of salt for me. Landi Pools and Games in Vineland, NJ.
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    May 2017
    NC
    1
    Thanks for posting. I'm in eastern NC and have 2 quotes for a 20x40 Roman end. So far $5,000 and $4,300. Waiting on the last quote.
