Thread: Recommendation for Leaf Pool Cover
    Apr 2017
    Phoenix
    500
    Pool covers aren't very common in Phoenix, probably because the water doesn't need any solar heat during the hot swimming months. However, my pool has a large ficus tree hovering over it. It's great for the much needed shade, but a ficus is a never ending battle of staying on top of the constant leaves and seeds. The first week in my house, we had a wind storm while my pump was running. My skimmer was so full in few hours that the lid popped out
    Anyway, I'm trying to find a solution to the endless battle. Mostly, I'm afraid for when I travel that I can't keep the pump on because of fear that basket gets too full. I'm looking around at covers, and found a few leaf nets for pools. I need one that will catch leaves and pee sized seeds. Also something that is easy to place on and off pool without the need for a cover underneath. Also need to be able to circulate water underneath.
    Anyone have any experience with leaf net covers? Any recommendations?
    16,000 gallon in-ground pebble tec pool. Hayward SP3400VSP Eco-Star Pump, Pentair Triton 2 TR-100 sand filter, A&A 5-port in-floor pool cleaner, Pentair Intellibrite 5g color changing pool light, Polaris 965iQ Robotic Pool Cleaner, OG Pool Math Subscriber and most importantly a Taylor K-2006C test kit.
    Test Kits Compared
    | SLAM | Chlorine / CYA Chart |
    Feb 2015
    Chandler AZ
    1,061
    Re: Recommendation for Leaf Pool Cover
    Sorry, I can't assist with your pool cover question. Any chance someone could stop by every few days to empty out your skimmer while you're away?
    While I appreciate the want for shade around our pools here in the desert southwest, over time that ficus tree will cause you more problems than just the litter from the leaves and fruit. Their roots can be quite invasive - even to the point of causing structural damage to your pool.
    What Is a Safe Distance to Plant Ficus Nitida From the Pool? | Home Guides | SF Gate
    Sorry to say, but judicious use of a chainsaw now will help prevent possible future costly problems.
    Pretty much any tree or plant is going to cause some litter. Here's a Google search result for best trees for poolside in arizona - Google Search
    You may also wish to consider a shade sail to provide shade over/around the pool.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Apr 2017
    Phoenix
    500
    Thanks proavia. I know the ficus is going to be an issue. I just bought the house and learned in the sellers disclosure that the previous owner had already had to fix the pool because the ficus was bending the rebar.
    The problem is that it's huge. Over 35 years old and going to take a professional crew to come remove it, possibly with a crane. It's something we are saving for and will need to do in next couple of years.
    Test Kits Compared
    Oct 2014
    San Antonio, TX
    450
    If you do a search on katchakid, they sell a leaf cover. Not sure if they do business in Phoenix area. Cost in San Antonio area for up to 20x40(I think) is around 2000.
    I have the safety net and then a leaf cover that rests on it and tucks in around the edges. Keeps everything out except rain and sand and very fine pollen. I went from oct 1 to almost apr 1 with the cover on and never once cleaned a skimmer. And I have a lot trees leaves and pollen
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
