Thread: New pool owner, excited to get to work! NEED LOTS OF HELP!
    Apr 2017
    LOS ANGELES
    3
    Hello all!
    I have signed up on a couple of pool forums today, trying to get started on a pool I recently got permission to work on.
    I want to say I like the approach of this site, especially the "Methodology" approach, which I am a fan of as it will help me understand the bigger picture.
    Anyway, I am going to copy the post I posted elsewhere here as well, and hope to hear form some of you!
    ____
    I'll try not to be a forum dummy, and promise to be honest and work hard for any reasonable advice I get.
    Here goes nothing.
    ____________________
    Hello everybody,
    I found your forum after looking around online for info on a pool I recently got permission to work on.
    I have a few heads ready to get to work, and invest in this thing, but it hasn't been in service for a long time, and recently got filled with rainwater.
    It's really gross and green, and I took a couple of pics to get started.
    We used to use this pool until my uncle passed away, and it has sat for maybe five years. I was told the pump and filtration work, and are newer, as in replaced right before it stopped being used. I don't remember any issues with the pool other than the fact that we would not run the heater due to energy concerns.
    Well, here are two pics to get started, I figure you all can ask me questions and I can try and gather as much info as possible. If someone could guess the size and let mew know what to do first, I'd appreciate it.
    Image 1 - http://imgur.com/jMFNr97
    Image 2 - http://imgur.com/iJjbE39
    Any help would be appreciated, and yes I know the pool is nasty and is gonna be a heck of a project.
    Jan 2017
    Monterrey, NL, Mexico
    492
    Re: New pool owner, excited to get to work! NEED LOTS OF HELP!
    Welcome to TFP. Your pool does not look that bad. Your pump seams to be the newer type Variable Speed so that is a good thing.
    I have never seen that type of filter you have, so someone will chime in. It seams you have some broken levers on your shutoff
    valves. I would get a proper test kit and test before draining or filling. This way you can see where you are going. You have to
    clean all the dirt and organics from the water. About the size of your pool you will have to measure it yourself, no guessing.
    Let us know
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    Apr 2017
    LOS ANGELES
    3
    Ok thanks! I am busy now reading up on the methodology, and will be ordering my test kit friday. I also have a few people chipping in who are much handier than I am, but I am the computer/book guy, they are the elbow grease.
    Dec 2016
    Arlington, Texas
    291
    Looks like over half the water is already out. It would be easiest to drain that, clean up, and refill. That will be the least amount of work.
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    Apr 2017
    LOS ANGELES
    3
    I was surprised this wasn't the first thing recommended. How much is a pool full of water though? I'm in Los Angeles, any guesstimates?
