Thread: They stop every year when the pool first opens.
    brauh01's Avatar
    Jul 2012
    Yardley, PA
    69
    23,500 gallon IG plaster with pebbles, Pentair FLT FNS 60 DE (160 GPM flow rate), Pentair Model 320 in-line Chlorinator, Jandy Plus HP 1.5 HP pump replaced with AO Centurian 1.5 switchless motor; Aquacal Heatwave heat pump. Method: since 2012 transitioned from "pool-stored" to TFP! Get your test kits here: TFTestkits.net correct link for pool calculator: http://www.troublefreepool.com/calc.html
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    536
    Re: They stop every year when the pool first opens.
    I shoo them away..and other times my pool alligator does it job.. Having the solar blanket on seems to discourage them as well. They always leave little gifts behind in the water and when they do visit it's very early (6:30ish) in the morning.
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
