Thread: Length reagents last
    Jun 2015
    St. Francisville
    78
    Quote Originally Posted by OTPirate View Post
    Yes, Taylor Technologies, whom TFTestkits gets all its chemistry from, recommends replacing them every year. I find that some do last longer, but as a blanket statement, Taylor does recommend replacing annually.
    I'm curious about this as well and wondering which test last longer than others. I'm hopeful I don't get yanked for hijacking a thread but the question has already been asked by the OP.
    30k gal, IG, vinyl, Pentair Tagelus TA 60D sand
    JoyfulNoise's Avatar
    May 2015
    14,085
    Re: Length reagents last
    The reagents most susceptible to going bad are -
    R-0870 (DPD Powder)
    R-0871 (FAS Titrant)
    R-0011L (CH indicator)
    Those three can easily go bad from moisture and heat. All of the other reagents are fairly stable and can last quite a long time. Taylor gives a 1 year timeframe mostly as a warranty - they are basically saying that their reagents will work, as expected, for one year. Beyond that, you're on your own.
    Matt
