Thread: Chlorine Tabs?
    Apr 2017
    Flora
    1
    Chlorine Tabs?
    30,000 gallon plaster
    CYA 30
    FC 3.0
    PH 7.6
    I like the bleach method of chlorination and have been using it couple of years with good results as long as i am home.
    My problem is that i find myself needing to add at least some bleach (1/4 gallon) daily or every other day to maintain chlorine levels.
    (This is with minimal or no swimmers.)
    When i am out of town a few days my chlorine goes way down.
    Does this sound like normal chlorine usage?
    What are your thoughts on adding chlorine tabs to the skimmer while out of town?
    What type of tablets would your recommend?
    Or do i need to raise my CYA?
    Thanks
    Jun 2014
    17,327
    Re: Chlorine Tabs?
    AZOG, Welcome to TFP! A few thoughts/suggestions that may help:
    - Please update your location to clarify where Flora is. It makes a difference in our recommendations.
    - Using only about 1/4 gal of bleach in a 30K pool each day is very good. My pool is just under 18K and I add 1/2 gal each evening which equates to about 2.5 ppm. We always say if you can manage your 24 hr FC loss between 2-4 ppm, you're doing very well.
    - Can you use tabs? Yes, although they will have trichlor or dichlor stabilizer in them, so be careful that CYA doesn't get too high on you. Tabs are also acidic, so never place tabs in the skimmer. If you don't have an in-line chlorinator, purchase a floater and let them float around the pool that way.
    - If you have to leave town for a couple days, you might be able to simply raise your FC level closer to the SLAM level and it may last 2-3 days for you. If not, then a tab or two may help as well.
    Hope that helps. Nice to have you with us.
    Oct 2016
    Phoenix
    203
    Re: Chlorine Tabs?
    It doesn't sound like you travel that much. I wouldn't worry about using chlorine tablets for peace of mind while on longer trips away from home. I do that. Yes I gain some CYA but I also lose some during normal backwashing so to me, CYA rise is not a big concern compared to worrying about low chlorine levels.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    30,944
    Re: Chlorine Tabs?
    Where is Flora? (what state) It matters
