Thread: Pump motor Mystery Screw
    Apr 2017
    Windsor, Ontario
    3
    My Hayward Superpump was seized when starting it up for the season, so I dismantled it to free the shaft and got down to a further layer than necessary. After removing a screw on the AO Smith 3/4 hp motor, I realize it can't be screwed back in and can't see what it connected to. Was there a nut holding it in place that's fallen into the impeller? What's the point of the screw anyway? A pic's attached to help this make sense.IMG_0994.jpg
    22,703
    Re: Pump motor Mystery Screw
    That screw holds a retainer and, yes, it's important. You'll need to remove the end bell in order to get to the nut and put it back on.
    To get that end bell off you need to remove the 4 long thru-bolts from the opposite end. They may be under the end cover. If they are you'll need to remove that first.
    A word of caution! In older motors it's very common to snap one or more of the thru-bolts off trying to remove them. So be careful.
    Spray some penetrating oil (WD-40, PB Blaster, Etc.) into the openings where the bolts thread into the end bell and let it sit a while. You may be able to see the thru-bolt ends by looking into the small holes by the mounting bolt holes. They thread into the back side of the mounting ears.
    Apr 2017
    Windsor, Ontario
    3
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    There is a nut inside. If you look at this, part 13 shows screw and nut. Don't ask me what they hold.
    Jun 2016
    Martinez, CA
    241
    Bearing retainer. This prevents the shaft from moving laterally. There should be a piece of metal that the screw threads into that will come loose and fall away when screw is completely removed. During reassembly you install the rotor into that endbell. Install the bearing retainer and screw, than the rotor slides into the windings.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Apr 2017
    Windsor, Ontario
    3
    Thank you! That also explains this odd metal bracket that was left over.
