Thread: Need help with Hayward multivalve leak
    Aug 2010
    Lake Jackson, TX
    130
    Hi all,
    Hoping someone can help me figure out why my Hayward 710xr50 is spouting water from the center post. I made the mistake of doing maintenance because the handle was a bit stiff. Upon reassembly the center leaked very badly. I chose to do a full overhaul. I bought the kit from leslies, ouch, and installed. It's leaking just as bad. I think I may have reasswembled wrong but I haven't been able to find a good set of instructions or a schematic to verify.
    Thanks
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    8,550
    Re: Need help with Hayward multivalve leak
    Hey there Dickey, I believe most multiport valves are somewhat stiff when turning.
    Have you looked at Youtube for videos, I believe they have some on replacing the gaskets and such.... may we helpful to check it out.
    Good luck, I wish I had more useful information for you.
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    You either buggered-up the shaft seal on reassembly or the shaft itself is scored. There's a good exploded view here http://www.discountpoolzone.com/pump...0710parts.html
    Aug 2010
    Lake Jackson, TX
    130
    I did try you tube but didn't find anything specific.
    Thanks for the info, I'll have to pull it apart again and try and see what I did.
    Aug 2010
    Lake Jackson, TX
    130
    Aha! broken o-ring. Panic over please return to normal life. Thank you.
