Thread: Rain, Overflow, and New Fiberglass Pool
    Dec 2016
    Raleigh, NC
    107
    Help! We have been getting an insane amount of rain here for the last 48 hours and it will continue at least through the night. Right now our water level is approaching equal with the top of the fiberglass shell (still 3-4 inches of concrete decking above that). Should we drain to waste to lower the water level as quickly as possible? Advice???
    Sincerely,
    Newbie trying not to panic
    IG Fiberglass 16x37, 3ft6in-6ft Deep, 13,300 Gallons (540 sq ft), Pentair Sand Dollar Filter, Pentair Superflo Variable Speed Pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,917
    Re: Rain, Overflow, and New Fiberglass Pool
    Yes lower it. You do not want it to get between the lip and coping. Your PB did not add a overflow tube to the skimmer basket?
    Kim
    Dec 2016
    Raleigh, NC
    107
    Thank you Kimkats! Hubby just went out in the monsoon and drained 3-4 inches out of the pool to buy us some time. Excuse my ignorance, but what do you mean by overflow tube to the skimmer basket? Where might one very panicked pool owner find this device? Please, try not to laugh at my ignorance...we've only been on our own with this thing for about 2 weeks!
    Quote Originally Posted by kimkats View Post
    Kim
    Uncle Salty's Avatar
    Feb 2017
    South Carolina
    221
    I'm not too far from y'all and also getting pounded with rain, we've got about 4"-5" so far. I lowered my water Saturday in anticipation of all the rain and the water is just about level with the top of skimmer now, I'll drain to waste tomorrow. Worst part has been the temperature drop, my water went from 89* Saturday to 75*.
    Salty
    20X40 30,000 gal. Vinyl, AquaPlus Automation w/ T-15 SWG & AquaConnect, EcoStar SP3400VSP pump, ProSeries S310T2 Filter, H Series 400FDN Heater, Sense/Dispense with Stenner Pump, ColorLogic X 3, TigerShark RC990, ​Borates, TF-100 test kit, K-1766 & Speed Stir Finally done! Well Almost
    triptyx's Avatar
    Apr 2016
    1,476
    Quote Originally Posted by ny2nc View Post
    Not all pools have an overflow tube. If your pool is overflowing, you either don't have one or the rainfall is exceeding its capacity (far less likely).
    No worries, drain any way you can to keep the water level mid-skimmer.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jul 2012
    Tallahassee, FL
    33,917
    When you have a clear moment in the day you can look in your skimmer and see IF there is a hole on the side of the skimmer towards the top. Not many have it. The PB drills that hole then puts a small PVC pipe attached to it and going off somewhere to remove the overflow of water. The overflow is most often done in a plaster pool. I looked at your finished pool pics (man that came out SO pretty!) and you stand a chance of having one BUT I bet you do not.
    Good job hubby for going out to drain some water. Better safe than sorry.
    and dry weather for a while I hope for you.
    Kim
