Thread: First Time opening after a season of TFP
    Nov 2015
    Chicagoland, IL
    209
    We are opening the pool this week - I've tested the water, and generally things look good, but my pH is 8.2+. I'm supposed I get that in range before I add chlorine, yeah? And don't need to slam on first opening, as long as there's no algae?
    27,000 gal. plaster IG with round spa built in 2007. TFT-100 test kit XL w/ Speedstir
    Jandy CL580 cartridge filter. Jandy 1.0 hp filter pump, 1.5 hp booster/spa? pump.
    Aqualink RS One Touch controls. Paramount PC2000 In-floor cleaning system (1.0 hp pump?). Jandy LX pool heater, apparently broken.
    Missing so much gear due to previous foreclosure, it's sad.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: First Time opening after a season of TFP
    Adjust your PH. As long as your water is clear with no visible sign of algae, your CC is 1 or less, and you pass an OCLT on startup, you're good to go. Then make sure your FC matches your CYA requirements. Adjust as necessary.
    Jun 2016
    Jackson NJ
    99
    I have same situation (only that my pool is a swamp). But shouldn't we adjust TA first and see how that effects the pH?
    Vinyl IG 18x43 25,000 gallon
    Hayward Pro s244T 300 lb Sand (with occasional addition of clarifier)
    1.5 HP pump; Polaris 380 with booster pump; Hayward H400 gas heater
    TF-100 with SpeedSTIR
    Apr 2010
    East Texas
    10,158
    High or low PH will cause you problerms a lot quicker than high or low TA will. 8.2 is MAX reading on the test.....................it could be higher.
    Nov 2015
    Chicagoland, IL
    209
    Thanks! That was the direction I was leaning. Looking forward to seeing my pool!
