Thread: How important is pool water temperture to the CYA test?
    Apr 2017
    Hillsborough New Jersey
    30
    My water temp is 55 degrees. I read a post but cant find it about the CYA test and water temp. Not a noob pool owner, new to site/forums. Have been studying pool school and forums last 3-4 days and my re-education is a steep curve right now. Maybe my 60 year old brain is a bit overwhelmed..... I just don't think I am getting accurate reading. Here are last test #s
    FC = 0.5
    CC= 0.5
    PH= 7.0
    TA= 100
    CH=125
    CYA= >100
    When I do the test I lose the dot before it ever reaches the 100 mark, there's a 1.8ml line on the tube and I lose it there. In addition when I opened/uncovered my pool I needed to add about 20% of fresh water via my hose, city water, to the pool due to displacement. That's typical for my pool. I want to be sure about test results before using the calculator to treat, or SLAM the pool, and get an idea of how many gals of chlorine or soda ash I need to be ready for all the steps. Pool does not have debris, brushing done every other day right now until I start the process. I don't get a lot of biologicals in the pool but it is pollen season, so there is that. Pool is clear, no cloudiness to my trained eyes, I've owned this pool for 18 years, and have been accused of being overly critical of its cleanliness, but its really crystal right now, and that's after just 3 gallons of bleach and 10lbs of ash. I hope this info I've provided helps with the answer.
    Vinyl 18' X 37' IGP 3'/8' deep
    27,400 gallons
    Hayward DE 4800 filter
    Full Sun NO SHADE
    Taylor 2006 test Kit
    domct203's Avatar
    Jun 2015
    CT
    3,912
    Re: How important is pool water temperture to the CYA test?
    Quote Originally Posted by Splitshot View Post
    FC = 0.5
    CC= 0.5
    PH= 7.0
    TA= 100
    CH=125
    CYA= >100
    With CYA over 90ppm, you should do the extended (diluted) test. 90ppm is about the upper limit of the test:
    https://www.troublefreepool.com/content/220-CYA
    I've never ran any controlled tests to see how much temperature effects the test, but the consensus here it that cold water will give false readings. I drop my 60ml sample bottle into a cup of hot tap water for about a minute or three when the water is below 70F. I do it just like I used to warm up my kids bottles, including a squirt on the wrist to see how warm the water is. When I feel it's warmer than 70F I proceed with the test
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Funny you should mention that. There's an ongoing discussion about temperature and CYA testing in the Experts' Secret Lair. It appears the reaction is slowed, but not significantly, at low temperatures. We're talking only a matter of a few seconds longer for the stuff to cloud. If you mixed it for a minute, you've more than compensated for any temperature differences. Also, cold water would make you read lower than actual were it to be a problem, and you're having the opposite.
    The question remains: how did the CYA get so high in the first place? The most common source is chlorinating with trichlor pucks. A close second is a weekly "shock" with dichlor powder. A distant third would be a pool "professional" doing the annual stabilizer addition without testing the current level first, but that can probably be ruled out in your case.
    To get a closer reading for what your actual CYA level is, use the dilution method in Pool School - CYA
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Oh, to be a fly on that wall...
    I'm still waiting for it to be nice and sunny out while I'm home so I can do the test properly. I had to do the mock run in my kitchen.
