Thread: Pump repair questions
    May 2014
    Hunterdon County, NJ
    32
    Towards the end of last season I noticed water seeping out of my superpump, and if it was shut off for several hours it would lose prime. I just replaced my pump with a PureLine model from INYO, the replacement was a breeze. Since the old pump is at least 15+ years old I thought replacement was the best option. I am now looking at the possibility of rebuilding the old pump and using it as a backup, or for utility purposes with the pool. My question is, as you can see in the below pictures that the pump is in pretty rough shape and the shaft is corroded, do I need to clean up the shaft with some emery cloth or just leave it and replace the seals?
    Sent from my iPad using TapatalkPump to motor.jpgAttachment 59728Attachment 59729
    If the photos are too big let me know I'll try to resize them, or a mod can adjust.
    20500 gallon Grecian type 2 pool built in 1980's, Vinyl liner approx 2001
    2 Skimmers, 1 Dedicated Vac Line and 3 returns
    PureLine Prime PL2601 Pump - Hayward in line Chlorinator
    Triton TR-60 Sand filter
    Dolphin M3 robot, TF-100 with XL option & Speed Stir
    Re: Pump repair questions
    I would clean it up before replacing the seals.
    Support the site
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    A green or red scotch bright pad will clean the shaft up no problem. For a 15yo pump it actually looks in pretty decent shape.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2014
    oklahoma
    10
    That pump looks a heck of a lot better than the one I just rebuilt. Hardest part of the whole rebuild was getting the corroded screw out of the endbell....the one near the shaft in your first picture. Everything else is pretty easy and there are tons of videos out there to watch if you need help.
