Thread: Another General Contractor and Cost Plus Pool
    ctrav's Avatar
    Apr 2017
    Northlake TX
    2,232
    Hello to all...I am new to this site and considering a cost plus build as well. My contractor has built several pools in the area and gets high marks from everyone I have spoke with. My pool is approximately 36x20 freeform style and bid has come in at $53K. A big cost is decking since I have about 1100 sf, perimeter 105' and pool area 696 sf. Does this seem correct? Other bids from actual pool companies is $60k plus....also I have a large yard of 1 acre property so is a freeform pool better or should I consider more of a straight line pool considering yard size?
    Thanks in advance...
    Feb 2017
    Las Vegas
    885
    Re: Another General Contractor and Cost Plus Pool
    The cost is going to be relative to the area you live in but from what I see on here 60k is nothing out of the norm for the size your saying. I would say that there are many other variables like type of decking, equipment , automation , heater, spa, water features etc that can drastically change your pricing.
    If you would post a pic of the design and equipment that would be very helpful.
    Also if you do a traditional square pool with the same dimensions you will have more surface are and more sqft which would drive your price up more typically. At that point the price should be a huge difference so my recommendation would be to go with the design you love best since you will live with it for many years
    Please ask if you have more questions
    current build<--free form gunite 34x21 18k gallons 4ft-7ft deep,Pentair 3HP VSP, wisperflo 2hp, 520 cartridge filter, 400k heater, ez touch 8 with screen logic, ic40 swg. 4ft sheer decent, 2 led deck jets, 5 globrite leds,rock spa waterfall. Mocha travertine deck, noche coping. Tropics blue custom mix with LOTS of beads and shells
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,150
    I think either can look good in a large yard. Our yard requested a rectangular pool.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    It's purely opinion, but I think free form vs straight line sets a tone for the yard. Free form, playful and open, informal - and then you can do most anything to the yard. I think the straight line just always sets a much more formal tone, some will depend on materials as well. Oklahoma stone or similar will make it less formal, travertine or stone with straight lines and hard cut edges more formal. Darker greys seem more formal to me as well.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    Jul 2016
    DFW
    40
    That's a pretty good price for the size. I live pretty close to you (Colleyville) and my quotes on a 15 x 30 rectangular with spa were coming in around $50K with about half the deck size you have. We ended up going the owner build route and saved about 20%.
    Owner Build in DFW - In-ground 13,500 gallons. Jandy 2 HP Variable Speed, Zodiac 1.5 HP Blower.Hayward 400 DP Propane Heater, Polaris Vac-Sweep 360, Pentair Quad 60 DE Cartridge Style Filter, Micro Fusion Pebble, Taylor K-2006 Test Kit
