Thread: Can I robot clean
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    Can I robot clean
    So, just took a peek under the covers and see the water is clear, but there is a bunch of small dirt debris everywhere.
    Can I use my dolphin before I even take the cover fully off?
    Water temp at 47.
    In ground Liner, MBP-125A Heat Pump by Aqua Heat , built 2003, 18x37 Grecian style, System 3 sta-rite filter. @22,000 gal, tftestkits TF-100 & 1766, USQ1102pump installed 6/2016, new liner installed 07/2017. Circupool SJ40 SWG (7/2018), Dolphin S300i 7/2016
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Can I robot clean
    Yes, my robot does fine cleaning under the solar cover.
    Ellington, CT
    307
    Sent my robot in under cover today, This is how I always do my openings. In April, get the pump circulating the water, add some chlorine if needed and send in the robot to to clean up the bottom. I don't pull the cover off until mid-May,
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, Maytronics Active 30i cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    Quote Originally Posted by laprjns View Post
    So, you pull out gizmos and start pump before removing the winter cover?
    Sorry for silly questions, this is first open for us.
    Ellington, CT
    307
    Quote Originally Posted by PureLuck View Post
    Yes I do.
