Results 1 to 20 of 20
Thread: Gunite Problem- What's the solution? Please help!!!
    Dec 2015
    Newport Beach, CA
    78
    The pool drains are off center. How can this be corrected at this stage?
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,880
    Re: Gunite Problem- What's the solution? Please help!!!
    A jackhammer and reshooting that section after the plumbing has been moved.
    Honestly if it were me, I would leave them as is. With surface matched drain covers they will hardly be visible and tearing into your pool shell can create a whole new set of issues if not done correctly.
    Another option, since it looks like the stub on the left is centered, is to cancel the right stub and use one of these instead:
    -Brian-
    Pool/Spa, Pentair Equipment
    Dec 2015
    Newport Beach, CA
    78
    Thank you for your suggestion. Unfortunately we are having an all glass tile pool so the appearance of the pool floor is very important to us. I will look into your drain idea. Anyone else have any suggestions/thoughts? Appreciatively, AJB
    Quote Originally Posted by bdavis466 View Post
    jdoty1977's Avatar
    May 2016
    Little Elm TX
    38
    Maybe they can add a third drain on the other side so it is at least symmetrical? Or at least a dummy drain.
    2016 Build: 20x30 15K Gal-IG Gunite, #4 Steel Tanning Ledge, Bubbler, Flagstone Coping, Stamped Concrete Deck, Jump Rock, Rock Waterfall, CLI Majestic Isle Pebble Finish, 3 Multi-Color LED lights, Ozone-DEL Eclipse 10, Empty Inline Tab Feeder, 2 HP Jandy Pro Series ePump with SVRS, 2 Skimmers, 6 Returns, 2 drains, 1 Cleaner Return, Jandy CV Filter 460 SF, Dolphin Nautilus+, iAqualink RS Automation, Borates, Test Kit Taylor k2006
    Jan 2012
    'burbs of Augusta, Georgia
    8,583
    I'd vote for the dummy drain over digging out the right one, and if that idea of BDavis' isn't suitable. ANYthing rather than blasting out that gunnite!
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jan 2011
    Richmond, Texas
    596
    The one in the middle does not look like it is exactly centered. I dont think a third dummy drain would work.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Jan 2012
    8,583
    No, you're right- it won't technically work, but it will even up the appearance which would improve aesthetics.
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Sorry for the problems - this doesn't help the situation any, but it drive me nuts the incompetence of the PB and their project managers to look out for things like that. I had my company move drains in the spa and pool and they still look a little wonky - but they were going to leave them.
    I'll have to search for a pool build thread from you, if you have one. If not I hope you'll share more with us, that will be an incredible pool of all glass tile - would love to see it progress (and the solution you come up with for the drain.)
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    Jul 2015
    Central Valley CA
    1,166
    How about getting rid of all the drains? Many pools on the east coast don't have them, I think is is one of those we do it because it has always been done that way kind of things. If you do that they may have need to add is an equalizer port which may pose a challenge at this point but I bet they can come up with a solution.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2013
    Sacramento, CA
    2,769
    I would have your PB either eliminate the drain. Its not required on a residential pool in California. Or install the drain Brian suggests.
    mas985's Avatar
    Pleasanton, CA
    11,987
    Aren't the drains for the spa?
    Mark
    May 2016
    Woodland, Ca
    235
    Can I request that you post pictures of your all glass tile pool upon completion.
    That. Sounds. Awesome!
    Build Video 2016 -- Solar Pad 20.5K gunite (37'x15') rectangle (3.5'-7') deep-- MicroFusion Laguna finish -- Jandy VS pump, cartridge and iAqualink RS -- Polaris 360 Black -- 2 Laminar jets -- 2 nichless 30w color led -- 550sq/ft Heliocol solar -- Soft water auto fill -- Stenner 17gpd
    Dec 2015
    Newport Beach, CA
    78
    Thank you everyone for your suggestions. Our PB says that this was intentional since we have a raised pool, we will not see any drains until we get very close to the pool... This is legit but I still may have opted for the 2 centered drains and would have preferred at the very least having the options mentioned prior to the gunite.
    Dec 2015
    Newport Beach, CA
    78
    I would be happy to post pictures but after spending a lot of time figuring it out, I still struggle with uploading pictures to TFP. I think I am at my picture upload limit and when I share a flickr link, all of my personal pictures are accessible, sorry.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Dec 2015
    Newport Beach, CA
    78
    Thank you for your support. I saw this and it doesnt work for me. There is no "upload pictures" button even though I am logged in. Thank you though.
    Quote Originally Posted by pooldv View Post
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I like Brian's idea, the dummy, or leave it. No one will care but you, and I promise it won't be that bad. I'd rather it be centered too, but I sincerely think it won't bother you with a little time. I wouldn't want to risk breaking up the shell if it were me. Maybe it wouldn't be that bad, but that would always be a worry in my mind. I hate having a nagging doubt that will sour the whole experience, and cutting the shell would put that in place for me. It can be done, but it will be no small task done right.
    Essential Links:
    Dec 2015
    Newport Beach, CA
    78
    Thank you, we will leave the drains in the current positions. There is some logic to not being able to any of the drains when in the main area of the backyard so I'm going to live with that. I appreciate yours and everyone's thoughts/help. Thanks,
    Quote Originally Posted by Patrick_B View Post
    Feb 2017
    Las Vegas
    885
    You can always open a new photo bucket account just for your pool build. A lot do it here and it's easy
    current build<--free form gunite 34x21 18k gallons 4ft-7ft deep,Pentair 3HP VSP, wisperflo 2hp, 520 cartridge filter, 400k heater, ez touch 8 with screen logic, ic40 swg. 4ft sheer decent, 2 led deck jets, 5 globrite leds,rock spa waterfall. Mocha travertine deck, noche coping. Tropics blue custom mix with LOTS of beads and shells
  20. Back To Top    #20
    Dec 2015
    Newport Beach, CA
    78
    thank you, I am using photobucket now... works well.
