Thread: Four year old Polaris 280 pulling to the left?
    Sep 2016
    Katonah NY
    170
    Hi,
    My Polaris 280 is pulling to the left side of the pool. It is 4 years old & besides a replacement bag it hasnt had any work done to it.
    Any suggestions on how to fix it or if I should replace it?
    Rich
    Apr 2013
    Sacramento, CA
    2,769
    Re: Four year old Polaris 280 pulling to the left?
    Pull it out and give it a food once over. All the gears correctly meshing. Tail swinging free.
    If the gears or wheels are worn you may need a tuneup kit.
    Amazon.com: polaris 280 repair kit
    Polaris 280 / 180 Factory Tune Up Kit - A49 - INYOPools.com
    Jun 2016
    Lake Dallas, Texas
    73
    We also have a P280. Some things to look at. Is the tail jet still pointing straight back? Are ALL of the wheels being driven by water pressure? Is the feed hose starting to get stiff? You might be ready for a a tuneup kit or a rebuild kit. Both have different parts in them. You might also be ready for a new feed hose. In the Texas sun, we can only get about 3 years out of a hose before it starts getting stiff.
    Bryan
    33,000 Gallon In Ground Gunite/Plaster
    1.5 HP Pentair Wisperflow 2 speed pump and Pentair 60 DE filter
    3/4 HP Pentair Booster pump and Polaris 280 cleaner
    Cirrcupool SJ55 SWG. TF100 test kit
