Thread: Testing pH, seems to rise after test tube sits a while, normal?
    Jun 2015
    Glendale, AZ
    158
    I always test pH first, I will leave it sit go on to test FC, then rince both tubes.....I always notice that the pH has risen say to 7.8 after initial test of 7.6 within just a couple of minutes....is this normal?
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    Re: Testing pH, seems to rise after test tube sits a while, normal?
    yes it is normal. When you do the test, consider the immediate result as what the pH is.
    Divin Dave,
    Jun 2015
    Glendale, AZ
    158
    Quote Originally Posted by Divin Dave View Post
    sounds good, thanks
