Thread: Tiki torch oil in pool!
    Oct 2016
    Tampa
    29
    Kids were climbing on the waterfall and accodentlybknocked over a tiki torch and oil dropped in the pool. Oil was visible on the surface. I added pool first aid. That seemed to have broken up the oil on the surface almost immediately. How long should I keep everyone out of the pool? Nothing on the bottle ifbpool first aid says anything about not to swim. I should add that other than the oil, the pool is safe to swim in. Thanks!
    Pentair Intelliflo 2 VST variable pump. Pentair Cartidge filter. Pentair intelliclor SWG. 11,910 gallons, waterfall and bubbler, Wetedge luna quartz finish in St. Maarten
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Tiki torch oil in pool!
    Ok,
    I would keep everyone out until you get all the oil out.
    Essential Links:
    When you get a chance, clean the cartridge.
    Support the site
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    507
    Can you burn it off? Please take pictures of the flaming pool!
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Raise FC level up close to slam level for your CYA, FC/CYA Chart
    30,941
    How much? 1 drop....1 teaspoon.....1 gallon
    It matters.
