Thread: Organic debris in DE filter grids
    Sep 2014
    San Antonio, TX
    4
    Question Organic debris in DE filter grids
    Hi all!
    I'm just now opening up the pool for the summer and, as usual, I'm taking apart the DE filter and giving it a thorough cleaning. This is the 4th year of doing this. However, for the first time, I have small sticks and bits of stick stuck inside of some of the filter grids where I can't get to them. I was able to manipulate a couple of larger pieces to the bottom and them flush them out of the main tube in the center, but it would take me hours to do this to all the bits I see. My question is, are these organic bits going to cause me a lot of headaches with algea control this year? Or will the chlorine keep them inert? I'm not even sure how they got past the skimmer basket to the INSIDE of the grids. There are some larger bits than what are shown in the photos, maybe 1/2" in length, but I couldn't find them now that the grids are dry.
    Thanks for your input!
    Mike
    12x23 AGP
    Vinyl liner
    Waterway Crystal Water DE filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Organic debris in DE filter grids
    They probably got in during a backwash.
    The chlorine will eventually oxidize them, but it might not be in your lifetime. I doubt they'll cause any grief.
    Sep 2014
    San Antonio, TX
    4
    Ha! I won't hold my breath then. Thanks, Richard! I'll carry on with the setup.
    Thanks again!
    Mike
    12x23 AGP
    Vinyl liner
