Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: Does a salt water get regular shock when first opened ?
    Jun 2016
    inman ,s.c.
    61
    Red face Does a salt water get regular shock when first opened ?
    Hi , we will soon be opening our new pool .it has a salt water generator and we have been told when we first open it that we should use regular shock in it ,so i am looking for some advice . thanks
    Jun 2016
    Locust Grove, GA
    62
    Re: Does a salt water get regular shock when first opened ?
    Second season of new 41k gallon saltwater pool here...Never once have I shocked it and the water has always sparkled.
    50x20 IG, quartscapes finish, 41k gallons , Autofill valve, Jandy pro series stealth 2 HP pump, Polaris PB4-60 cleaner, 4 cartridge filter (unknown make), Hayward Turbo cell 15 swg, Rheem 135k BTU heater/chiller, Hayward Pro Logic control panel, pool build complete 6-10-2016
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    vera,
    Is your water clear or not? If green or cloudy you need to SLAM your pools using these instructions.. https://www.troublefreepool.com/cont...tain-shockingl
    If clear than I would add enough Liquid Chlorine/plain bleach to bring your FC up to the level you normally run.
    Apr 2013
    Sacramento, CA
    2,769
    As Jim says if its not green or cloudy get the pool up to the proper chlorination for you based on your CYA level. Then wait a day or two to see that its stable then turn on the SWCG.
    No need to shock the pool.
    Jan 2012
    'burbs of Augusta, Georgia
    8,585
    I wonder if the person who told you to "shock" your pool just meant to say "put in enough chlorine to get it up to your desired level so that the SWG can then be turned on and it will maintain that level."
    If your FC is low, the fastest way to bring it up to desired levels is just to use bleach. That's liquid chlorine at its best! No bother with other odd pool store products called "shock"..... they also contain other stuff you may not want, y'know?
    Bleach, Baby Bleach!!
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jun 2016
    inman ,s.c.
    61
    Hi , we just got it uncovered due to a lot of yard work going on .it is green and some of it may be due to orange dust getting through from yard work . so we should not turn the swg on? this is going to sound really stupid but how do we run the filter without the swg being on ? Thanks
    Dec 2016
    Arlington, Texas
    291
    At this point, you will want it clear before starting the SWG. Please fill in your signature so we know your equipment, but typically you either have an off switch if the SWG is a separate unit, or you may just have to turn it down to 0%. Knowing your equipment can help us tell you how. Also, what testing kit do you have? You will need to run the pump for about 30 minutes then post a full set of test results.
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    Jun 2016
    inman ,s.c.
    61
    I am not sure how to fill in my signature but I can tell you we have an 18x 36 vinyl liner pool with a Hayward super pump and vari flow with a AQR 15 SWG . Not sure if that what you need to know . Thanks
    Oh and the TF -100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    More here on how to add a signature and what to put in it, Pool School - Read This BEFORE You Post
    Jun 2016
    inman ,s.c.
    61
    We put shock in this morning and the pool store guy said we should have used theirs because the Clorox one has copper ,the pool looks much better than it did yesterday. which is a good thing since I overextended my reach and did a header into the 6 ft. end . Yuck . I had also purchased an algaecide for my salt pool but it also has some copper in it .
    DFW, TX
    24,974
    We are 110% against adding copper to your pool in any form. It builds up and stains pools, hair, fingernails, dogs, etc. There is no way to remove copper from the pool except to drain the water. Lots of people on TFP have spent a lot of time and money trying to deal with copper stains in their pools. Much better to never add it in the first place.
    Dec 2016
    Arlington, Texas
    291
    Ok, at this point you either have to decide whether you are going to continue listening to the pool store people, or you are going to never step foot in there again and do this the full blown TFP method. Everything they tell/sale you will be in contradiction to what we practice, or at least mess with your chemistry that we are trying to get you to.
    We will walk you through every step and tell you the actual why behind everything you are adding, but you can't mix their advice with ours.
    May 2012
    Toronto, ON
    472
    Every year when my pool is uncovered it is green and/or rather dirty despite the fact that we generally open it when the temperatures are still cool - this year the water temp was 48F when uncovered. The pool does get shocked and clears after a couple of days and a bit of vaccuming. I generally use Liquid chlorine until the temperature gets warm enough for the SWCG. I measured the FC a couple of days after opening and it was at 11.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    Jan 2012
    8,585
    Quote Originally Posted by wayner View Post
    Do you close it when the water is cold too, and at SLAM level?
    Maddie
    May 2012
    Toronto, ON
    472
    The water would generally be in the 60s or below when it is closed and I think it does get shocked with Chlorine - but I don't do it myself so I am not 100% sure.
    DFW, TX
    24,974
    We recommend closing and opening below 60.
    Jun 2016
    inman ,s.c.
    61
    Ok, so my question is if I don't set foot in the store again ,where do I buy my chemicals ? The ones at the store ,even the algaecide has a small amount of copper. I am opening up my TF -100 kit .Usually my husband does this but he cant get to it until the weekend .it looks better todaybut needs a good vacuuming . we haven't gotten a robotic cleaner yet but that is in the not to distant future ! so for now just using the old fashioned one but I am having trouble reaching the deep end . They also recommended using a flock to gather the stuff and sink it to the bottom and then vacuum . Thanks
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Here is an article on recommended pool chemicals. Pool School - Recommended Pool Chemicals It includes common places to get them as well.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2012
    Toronto, ON
    472
    Quote Originally Posted by vera jane View Post
    At Wal-mart or a hardware store. You shouldn't need algaecide. You shouldn't need much in the way of chemicals, hopefully just liquid chlorine, muriatic acid and baking soda. And you shouldn't need chlorine once your SWCG is working properly.
    The one thing you may need from a pool store is Cyanuric Acid aka Stabilizer and you need more of that when you have a SWCG.
  20. Back To Top    #20
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    You can get stabilizer from Walmart or other stores, too No need for pool $tore.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
