Results 1 to 8 of 8
Thread: New Breaker Needed for Pump
    May 2016
    Toledo, OH
    81
    Hi everyone. I need to replace the breaker for my pool pump but all of the info on the breaker has been rubbed off. Here is a picture of the nameplate on the motor. Thanks for the help!
    15,500 Gallon - In-Ground - Gunite Pool - Kidney Shape / Hayward S220T Sand Filter / 3/4 HP Hayward Pump / K-2006 Test Kit / Chlorine 3" Pucks
    Mar 2016
    Easley, SC
    407
    Re: New Breaker Needed for Pump
    Either a 15 amp of 20 amp GFCI would work.
    18x36 inground / 28k gal / Vinyl liner (replaced in 2018) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump / Stenner pump (85MHP17) w/55 gallon storage tank / Pentair heat pump HP1200 (To be installed) / TF100 Test kit
    May 2016
    Toledo, OH
    81
    Thanks. I was thinking 15A
    May 2016
    Toledo, OH
    81
    Quote Originally Posted by joshua5438 View Post
    Sent from my SM-G900V using Tapatalk
    Does it need to be double pole?
    Mar 2017
    Lake Forest, CA
    16
    Check the current setup per the diagram on the upper right of the label. See which position the black arrow is in. If it is 120V then you can use a single. Is the pump on a dedicated circuit?
    Mar 2016
    Easley, SC
    407
    What he said. 120V is single pole and 240V is double pole. Hopefully it's already on it own circuit. Just make sure the new breaker is GFCI per latest codes and for safety. I currently have my main pump and booster on one 20A breaker, 240V with no issues. I ordered the breaker from Home Depot as they had the best price.
    May 2016
    Toledo, OH
    81
    Great thanks. Yes the motor is wired for 240v
    Apr 2013
    Sacramento, CA
    2,769
    Then you need a double pole 20 or 15 amp GFCI breaker.
