Results 1 to 11 of 11
Thread: Very small chip in outer edge of new shaft seal...still good/ok to use?
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    After waiting for over a week now for my new seal plate and shaft seal to be delivered, I noticed a very small chip on the outer edge of the black side of the shaft seal (the half that has the spring) after I had already went through all the trouble of installing it and attaching the new seal plate to the motor mount plate, so I would like to be able to use it if you guys think it would still be ok. Plus I would like to get my pool water circulating again asap. What do you guys think? Maybe I'm being a bit too picky. I REALLY don't feel like having to return it and wait for another one, but I will if I have to.
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin S200 Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    Yuma AZ
    72
    Re: Very small chip in outer edge of new shaft seal...still good/ok to use?
    Looks good to me, this side seats against the ceramic side of seal. That's a good job though finding this minor defect. That's something I love about this forum, it never hurts to ask.
    10,000 gallons IG Freeform, 8ft raised spa,pebble finish
    FNS 60 Sqft DE Filter,2HP Whisperflow for Pool/Spa filtering
    2HP Whisperflow for Spa jets
    1HP Whisperflow for Waterfall
    Master Temp 400,000 Btu Heater
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Just didn't know if it would eventually affect the integrity of the seal (water eventually leaking through at the chipped part).
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    So the white ceramic face on the other half presses up against the black side of the one in picture or does the white ceramic seat inside in that inner circle groove (I noticed the white ceramic half is sitting in a black rubberish insert)? With both faces spinning against each other (isn't that how it works?), you don't think it could catch in that area and chip off more?
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    On the right is the leaking seal that I just replaced. The new seal is on the left. The pump is 8 months old, and was off & drained from the end of October to the first week of April. It has never run dry. It started leaking after I opened a couple of weeks back. These things are pretty unforgiving. If you do use the chipped seal and it holds, I wouldn't count on it having a long life.
    Where did you order from? Mine was on Amazon Prime with 2 day shipping.
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Quote Originally Posted by cjpwalker View Post
    That's what my main concern is, they seem to be pretty fragile. Basically I'm worried now that the integrity of the seal may be compromised therefore shortening the life of the seal. Yes I ordered it off of Amazon. I think I may just call the company and let them know of the defect. What you think?
    Also, do you think I would be able to get the seal out (by pulling it) without having to take apart the seal plate from the motor mount plate again (that was a PIA)?
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Amazon is pretty great about returns. I've had a few over the years, and usually they ship a replacement at no charge, and give you plenty of time to return the defective part before they charge you for the 2nd one. For defective stuff I've always received a free return label as well.
    Couldn't tell you about pulling the seal. On mine (Jandy epump) I did pull the motor off of the seal plate which popped the carbon side of the seal off of the shaft, and I then was able to punch out the ceramic from behind with a socket. Not sure if pulling on it from the front would break something or not...
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Well I just emailed the company (MyPoolYardCOM) to explain the defect and asked them to resolve the issue...waiting to hear back from them.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Any damage to either seal face is reason enough not to use the seal. If you received it in that condition they should be replacing it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Quote Originally Posted by CJadamec View Post
    CJadamec, the 2 seals were just thrown in the shipping box free to move about during shipping. This seal usually comes in a very small box and the 2 halves are secured. They weren't even wrapped up for protection! I contacted the seller (MyPoolYard.COM) who was VERY RUDE and told me that I needed to call Amazon to resolve the issue because I bought it from them and acted crazy when I told him that I really bought it from them (MyPoolYard.COM) because they were the 3rd party seller of the item. He hung up the phone on me afterwards! After trying to resolve the issue with them I called Amazon customer service who were VERY HELPFUL and issued a full refund and sent a complaint for this seller to their investigation team who will be calling me back.
    Anyways, do you think i will be able to get/pull the seal out of the seal plate without having to take the plate off from the motor again?
    Also, when I get the damaged seal out and I put the new one in, would a small bead of silicone caulk be ok to put under the metal lip of the seal and then push it into place? Or is there no need for this?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    The spring holds the seal in place I wouldn't put anything on the seal that it didn't come out of the box with. I hate dealing with bad customer service like that. I don't know if you need to take the plate off.
    Chuck-
