Results 1 to 7 of 7
Thread: No Pressure on Cartridge Filter
    Mar 2016
    Albuquerque, NM
    23
    Question No Pressure on Cartridge Filter
    I opened my pool and cleaned the filters for the first time on my Jandy CL580 today. I reinstalled them, opened the air release valve on the pressure gauge and started the pump. When water started coming out of the air release valve I closed the valve and checked the pressure gauge. It was reading 0 psi but I was getting water flow out of my returns. I let the pump run for about an hour at 2000 RPM and still had a 0 psi reading. My pool is only a year old so could it be a bad gauge or something else? Last year with new filters the reading was 10 psi.
    16K gal, IG, plaster, Hayward TriStar VS Pump, Jandy CL580 Cartridge Filter, Raypak 266 Heater, Pentair WhisperFlo single speed Water Feature pump, Stenner Liquid Chlorine pump, Zodiac MX-8 Suction Side Cleaner, Automatic Pool Cover, TF100 Test Kit w/Speed Stir
    40,851
    Re: No Pressure on Cartridge Filter
    Either a bad gauge or something is clogging up the port to the gauge.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,257
    mj,
    The important part is getting a good flow of water back to your pool returns. As long as the flow is good, then the exact pressure is not all that important.
    I agree with Jason that the gauge might be bad or plugged from inside the filter.
    My point is that it is not something that has to be fixed right now.
    Thanks for posting,
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    Bad gauge is the most likely culprit. The plastic OEM filter gauges don't last long. If you want to replace, I would recommend one of the glycerin filled nice gauges like this one. Well worth the few dollars it costs and the quality of the thing is immaculate. The scale on the gauge lets also be able to determine the precise pressure too.
    TFTestkits.net
    Divin Dave,
    Mar 2016
    Albuquerque, NM
    23
    Quote Originally Posted by Divin Dave View Post
    TFTestkits.net
    My gauge has the built in air release valve. Do they make a separate air release valve that a glycerin filled gauge could thread into?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    hummmm... looks like that might be new for Jandy. Ive never seen one like that. In looking at the parts list, the gauge is seperate from the relief valve but I have no idea of the fitting. Not enough info about the jandy gauge. The thing is pricey too it seems.
    If it were my filter, I would give Inyo Pools a call and see what it might take to replace the original air release with something that's a bit less customized.
    Jandy CL Series Cartridge Filter Parts - INYOPools.com
    Quote Originally Posted by mjbarr99 View Post
    Divin Dave,
    Oct 2013
    Bellingham, wa
    10
    I had that problem, fixed it by shutting it off, then removing the lid and basket and reaching into the impeller hole and removing pine needles wrapped around it.
    Hopefully within 2 weeks of 5/21/2017
    Intex 16x32x52" Ultra Frame Rectangular Pool 14,364 Gallons
    Intex 2,800 gallon per hour Krystal Clear Sand Filter Pump
    Intex Saltwater system
    Hayward H300FDN Universal H-Series, Low NOx, 300,000 BTU, Natural Gas heater
