Thread: Is an oversized liner ok or not?
    May 2011
    Bensalem PA (Philly Suburbs)
    83
    I am going to be ordering a replacement liner for my pool in the next day or so. My pool is 18' by 38 1/2', with a deep end, so I will need an overlap expandable liner. The cheapest expandable patterned liners I can find are for 21' by 41'. Since it's an overlap expandable liner, is it ok to get a larger liner and just cut off the excess? I seem to recall the original liner I got was like that. Or would a 18' by 39' fit significantly enough better to be worth paying extra for?
    Thanks for any advice/help.
    18' x 38' x 52" oval AGP with 6' deep end (foam on the walls, preformed coving, and Happy Bottom floor padding)
    Pentair Optiflow 1 HP 2 Speed pump
    Pentair cc200 cartridge filter
    Pentair UltraTemp Model 110 BLK 108,000 BTU Heat Pump
    2 Intex SWG's (copper unplugged)
    Casey's Avatar
    SW PA
    10,514
    Re: Is an oversized liner ok or not?
    You can not use a larger liner. You will have folds of extra material along the walls and floor.
