Thread: Spa heater kicks on then shuts off
    Mar 2017
    Riverside,CA
    1
    Hi
    I recently moved into a new home that has pool and spa. The problem is the heater kicks on, then shuts off right away. CAn somebody point me in the right direction of what part needs to be replaced or what needs to be fixed?
    Thanks a ton
    Andrew
    Apr 2015
    tucson, arizona
    1,312
    Re: Spa heater kicks on then shuts off
    You really need to include the make and model of heater to get proper help
    Aqua Lab Rat's Avatar
    May 2015
    Anoka, MN
    89
    Some spa heaters have 2 sensors that screw into them, the 2nd one for over-temp protection. If that's the case, the 1st sensor could be telling it that the heat needs to be on, and then a defective 2nd one could be shutting it down. Can't say more without some info else you could be sent on a wild goose chase.
    Lyle
    Professional product developer using & maintaining a dozen or so spas from 150 to 550 gallons, many pools from 1200 to 40,000 gallons (above-ground and in-ground), and a half-dozen test tanks.
    If it's not one thing, it's usually several others!
