Thread: poly quat 60 in borate pool
    Apr 2014
    Brookfield, CT
    18
    I just opened my pool this week. The water is clear:
    pH: 7.6
    FC: 7
    CC: 0
    CYA: 40
    Borate: 50
    CH: 70 (vinyl pool)
    TA: 90
    Temp: 53F (won't be going in any time soon)
    Should I add poly quat? If so, how much and how often? Should I worry about the TA being too high? Last year the pH never drifted up, but I'm using borate for the first time (used granular boric acid from Duda Diesel- very easy).
    21' x 41' vinyl in ground pool, 26500 gal. 1 hp Hayward pump, 4 wheel suction side The Pool Cleaner, Hayward EC-75 DE filter, Hayward SUMXL 140 heat pump, TF100 test kit with stirrer.
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Re: poly quat 60 in borate pool
    Im interested in why you think you need Polyquat? I've read that it usually used in closing your pool.
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    Apr 2013
    Sacramento, CA
    2,769
    Algacides like Polyquat are algae preventers. If you keep your pool within TFP guidelines there is no reason to use them under normal conditions. There are certain situations where there use is appropriate but they generally serve no purpose if you maintain your pool within TFP guidelines.
    May 2016
    Troy IL
    484
    Instructions from my pool builder said to throw in a bottle of polyquat on opening and on closing. However, I threw out those instructions and don't use it at either anymore. If I were going to use it, I would only use it when winterizing the pool. No need for it when I'm keeping a close eye on my chlorine levels through the summer.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
