Thread: New to SWG
    Luric's Avatar
    Aug 2015
    Central NJ
    84
    New to SWG
    WE just opened our pool after converting to salt last week. Our Intellichlor says Pool Output: 65%, Spa: 3%, Salt Level: 2850. I tested FC and it's 11!
    What did we do wrong (we haven't done anything since they were here 2 days ago and added more salt) & how do we fix it?
    Inherited 30k gal IG gunite black bottom pebble w/ waterfall & attached spa, built 1993ish; Pump: Pentair Intiliflo VS pump; SWCG: Pentair IC60; Filter: Pentair FNS Plus 60 SQFT DE; Heater: Pentair Mastertemp 400,000btu; Robot: Dolphin Nautilus Plus; Waterfall Pump: Hayward Super Pump 1.5 HP; Testing: TFTest Kit TF-100; Automation: ​EasyTouch w/ ScreenLogic
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: New to SWG
    Can't say that you did anything "wrong" per se or that 11 is completely off the charts. What are your full test results? CYA? Sounds like you just need to adjust your production levels to "dial in" the output needed for your pool and pump run time. For example, min runs well at 27% whereas others keep it at 80%
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,259
    Re: New to SWG
    Luric,
    Saltwater Chlorine Generators (SWCG) produce chlorine based upon two things. One, the percentage of output that you set, and two, the amount of time the pump is run..
    The amount of chlorine produced by setting the SWCG at 100% and running the pump for one hour, is the same as setting the SWCG at 10% and running the pump for 10 hours.
    The SWCG itself is dumb as dirt. It has no clue what the FC of your pool water is. All it knows, based upon the % you set, is how long to stay on each hour.
    You are the SWCG's brain.. You have to test the FC in your pool and then "tell" the SWCG to stay on longer and make more chlorine, or to stay off longer and produce less chlorine.
    Please let me know if this does not make sense...
