Thread: NO CYA, How do I SLAM???
    Apr 2016
    reading,pa
    3
    Good Morning TFP!
    Thank you in advance for your help.
    I have a TF-100 kit. I have opened my pool myself - I am up and running. I, unfortunately, got pool stored. I have taken over myself and need a little help to get a SLAM started.
    Here is my situation:
    water is cloudy, ever so slightly a hue of greenish-blue.
    pump is running 24/7
    FC - 2.5
    cc - 1
    TA 70
    CYA - 0 - a big fat ZERO!!
    What is the best/most efficient way to dose the stabilizer so that I can SLAM ASAP.
    I am thinking of raising my CYA to 30 for the SLAM ...
    15,000 gal, IG vinyl,DE Janet sftm filter, jandy pro valuable speed pump, 2015, jandy aquaflow SWG, Dolphin robot
    40,879
    Re: NO CYA, How do I SLAM???
    Welcome to TFP!
    I agree with your thought. Add enough CYA to target 30ppm and then start the SLAM. Otherwise the sun is going to destroy the FC too fast.
    Apr 2016
    reading,pa
    3
    I am thinking of investing in the liquid stabilizer - is that worth it? Otherwise, do I have to have to wait for the granules to dissolve before I start adding chlorine?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Quote Originally Posted by bjenjennifer View Post
    No and no.
    If you set the sockfull of stabilizer in the skimmer or in front of a return so there's a constant flow of water, it will all be dissolved within a day, most of the time. Just assume it's all there when you calculate the FC dose.
    Apr 2016
    reading,pa
    3
    Awesome!! Thank you so much - I am off to SLAM!!
