Results 1 to 10 of 10
Thread: Test results - first time!!
    Crystal Z's Avatar
    Aug 2016
    Houston, TX
    19
    Hi! I finally ditched the pool guy! I've been testing on and off since January to get used to it but this is the first time I am in 100% control. My pool guy has been slacking his last couple weeks and I noticed that while my water is completely clear, it has a slight green tint. Nothing too shocking, but I can tell a difference. So I need a little help determining exactly what to add. Here are my results from this morning:
    FC - 2.5
    CC - 1
    PH - 7.8
    TA - 80
    CH - 325
    CYA - 50
    Thanks!
    12k gallon, in-ground pool with spa, pentair 2hp main filter pump, pentair 1hp water feature pump, pentair 400k btu heater, pentair ez touch control panel with remote, pentair prowler 820 robotic cleaner, & wet edge 'blue lagoon' pebble
    Dec 2016
    Arlington, Texas
    291
    Re: Test results - first time!!
    If your pool isn't crystal clear, you should start a SLAM. Also, your absolute minimum FC should be 4 with a CYA of 50 per Pool School - Chlorine / CYA Chart
    Lower pH to 7.2 and start adding bleach/liquid chlorine.
    Pool School - SLAM - Shock Level And Maintain
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    I concur. Lower pH with acid. Make a lap with the brush to get things mixed and expose any algae. Then take FC up to 20 and recheck it every few hours and keep it up at 20. Filter running the whole time. It'll clear up quick. Just follow the directions in the link in the post above and you'll be fine. Just remember brush brush brush. The pool may actually look worse after brushing, which is good, because it means you got the stuff off the walls and out into circulation where the filter can get it.
    Crystal Z's Avatar
    Aug 2016
    Houston, TX
    19
    Ok thanks will do
    Dec 2016
    Arlington, Texas
    291
    Just to double check, you are using one of our suggested test kits, correct? The only way you can properly do a slam is with one of those
    Crystal Z's Avatar
    Aug 2016
    Houston, TX
    19
    Yes I have the TF 100
    Crystal Z's Avatar
    Aug 2016
    Houston, TX
    19
    Water was gorgeous yesterday, thanks for the help!
    IMG_6298_zpspsspczpj.jpg Photo by crystalzeglin | Photobucket
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    If you click get links, copy the IMG code and paste it in your post the pic will show up in your thread like this.
    Crystal Z's Avatar
    Aug 2016
    Houston, TX
    19
    I've been trying to post that picture since yesterday and all I could come up with was to add the link - thank you for the tip!
    DFW, TX
    24,974
    You're welcome! More here, Posting Photo's Tutorial
