Results 1 to 9 of 9
Thread: Help! Tested water don't know what to do
    Jun 2016
    Lehigh Acres/fl
    7
    I have a 14' x 48" round above ground pool. I filled it with my water two days ago we have well water. I shocked it twice and then took my levels this morning.
    Hardness-500
    Total Chlorine-0
    Free Chlorine-1
    Ph-7.8
    Total alkalinity-240
    Stabilizer-50
    What do I add and in what order
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    577
    Re: Help! Tested water don't know what to do
    First what are you testing with and clarify what you mean by "shocking it twice"
    Welcome!!!!!
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Pool School - Chlorine / CYA Chart
    There's a couple of good articles in Pool School to get you started. Your FC should target between 6 and 8. Forget the "shock" and use plain liquid bleach. Welcome.
    Jun 2016
    Lehigh Acres/fl
    7
    I tested it with test strips from Walmart that have an app attached to it. And I shocked it with the HTH 1 pound bag of shock. I used two of them
    QUOTE=clambert1273;1206695]First what are you testing with and clarify what you mean by "shocking it twice"
    Welcome!!!!!
    Jun 2016
    Lehigh Acres/fl
    7
    I know I should add ph down and chlorine (bleach) but should I add it at the same time or so I have to wait and do it seperaey
    Apr 2010
    East Texas
    10,158
    We recommend adding one, circulating for 30 minutes, then adding the next one.
    40,879
    You really should not do anything based on test strips. They are just not accurate or reliable.
    Also TFP does not recommend randomly adding a bag or 2 of shock powder. If There is a problem, we recommend following the SLAM process which requires a good test kit.
    Donldson's Avatar
    NW Ohio
    3,219
    The results you posted are great at showing why we never use test strips.
    The formula for Total chlorine is: Free Chlorine + Combined Chlorine = Total Chlorine.
    Your test results show zero total chlorine and one free chlorine. That is impossible, and good evidence to why test strips are not trustworthy. I'm afraid it doesn't matter if it comes with some nice looking app, they are not useful for accurately measuring anything.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    May 2016
    Massachusetts
    14
    I was new to this last year. Trust the forum. It may seem overwhelming at first but with a little reading it will start to make some sense.
    Your first step is go buy the TF-100 test kit. Once you have those results the Pool School and Pool Math will give you most of the answers you need. And those more experienced then me will help you along.
    But seriously...order the test kit right now.
    - 28,000 gallon (16'x40' - 9' at deep end) gunite
    - Sta-Rite DE 60 sq/ft filter
    - AquaComfort Heatpump
    - Haywood SP2302 Variable Speed Pump
    - Aquarite AQR15 SWG
