Thread: Water passing through SWG reaches breakpoint chlorination?
    Olga's Avatar
    Mar 2016
    Phoenix
    21
    Question Water passing through SWG reaches breakpoint chlorination?
    I read an article that mentioned that as water passes through the SWG it reaches breakpoint chlorination and gets rid of chloramines. Then someone commented saying that was a ridiculous statement. Intuitively the notion that breakpoint is reached in the SWG makes sense to me, since at the point of chlorine generation (in the SWG) the chlorine concentration would be incredibly high, thus at breakpoint. I've also noticed that my pool has never needed shock; combined chlorine has not been a problem.
    Google searches have produced no scientific articles that prove or disprove or even discuss this idea. I've found no sales pitches touting it as a benefit either, aside from the one mentioned above.
    Anyone have a link or thoughts?
    17,000 gal. saltwater, Pentair Intellichem, Ozone, Pebble Tech, 50' long negative edge
    domct203's Avatar
    Jun 2015
    CT
    3,892
    Re: Water passing through SWG reaches breakpoint chlorination?
    I really can't comment on the chemistry happening inside a SWG cell, but I will add that I have a manually chlorinated (12.5% bleach) pool, and following TFP guidelines my CC's have been pretty much 0.0ppm for three seasons.
    Do you have a link to the article you read discussing this?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    948
    I would also add that stuff gets into the pool that is oxidized to create CC's long after the SWG has created the chlorine.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    JoyfulNoise's Avatar
    May 2015
    14,083
    First off, let's stay away from the concept of breakpoint chlorination as it is a term used (or should I say, abused) by the industry and it has lots of misunderstanding associated with it. See these posts to understand the fallacies surrounding breakpoint chlorination -
    Certified Pool Operator (CPO) training -- What is not taught
    Is the formula for too high?
    To the idea that an SWG "superchlorinates" the water passing through it, you don't need much science, you just need to look at the numbers. Assume that an SWG is running at the slowest speed possible to generate chlorine which, for most models, is about 15GPM. AT that speed, one would expect the highest level of chlorination possible. For our purposes, let's use an IntelliChlor IC-40 cell -
    1.4lbs/day * (16 oz /lb) / (24 hr/day) = 0.933 oz/hr
    15 gal/min * 60 min/hr = 900 gal/hr
    (0.9333 oz/hr) / (900 gal/hr) = 0.00103 oz/gal of chlorine gas
    In terms of FC, the water inside the cell is seeing roughly 7.8ppm FC. If one has 70ppm CYA in the water (which is the lowest recommended level for an SWG), then the FC/CYA ratio is about 10%. That's hardly "superchlorination". Increasing the flow rate of the water through the cell (most pools operate at 40GPM or more) only dilutes the chlorine further.
    As others have stated, a manually dosed pool that is clean and clear will also have very low CCs. CCs are the by-product of chlorine reacting with bather waste (although not all forms of bather waste produce chemicals that register as CCs) and they usually only high in outdoor pools that are improperly cared for.
    Matt
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,261
    Olga,
    One of the benefits to using the TFP method, whether using a SWCG, or dosing with Liquid Chlorine, is that you never have to add "Shock" to your pool on a weekly basis.
    Thanks for posting,
    Olga's Avatar
    Mar 2016
    Phoenix
    21
    Thank you for the comments and explanations. The calculation about expected levels in the cell was very helpful.
