Thread: How long does Bleach stay usable?
    Sep 2016
    Katonah NY
    172
    Hi,
    So i am ready to fill my 30 gallon tank to give my pool LC with the stenner pump. I am a bit curious how long the bleach should be good until?
    it is really cold in NY & I dont expect i will be using much bleach for the next few weeks. My pump does 1oz per minute & It probably will use a gallon a day during the warmer part of the season (+/-).
    Can it sit for two months without going bad? It is indoors in a sealed container.
    http://i.imgur.com/1FTGeSD.jpg
    Rich
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,303
    Re: How long does Bleach stay usable?
    There's a chart at the bottom of this page, and it also has a link to some more technical stuff. http://www.odysseymanufacturing.com/about_product.htm
    Sep 2016
    Katonah NY
    172
    Wow! so 5% bleach off the shelf can last over a year @ 90f? Amazing!
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Yes, but it will be 2.5% bleach at the end of the year.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
