Thread: Retaining Wall Cleaning
    Jan 2014
    Dallas, TX
    69
    Is there a TPF type method for cleaning retaining walls and flagstone?
    I have a power washer and could use simple green or bleach but I'm hoping there is some magic formula like sodium bicarbonate and vinegar!
    26,000 gal / in-ground SWG (Hayward T-CELL-15) / Blue Granite PebbleSheen / 2hp WhisperFlo pumps (main), 1.5hp WhisperFlo pump (waterfall) / Pentair DE filter / AquaLogic control / Polaris cleaner aka "Trackie" / Dallas, TX
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Retaining Wall Cleaning
    Those two things will react and neutralize each other. Is it the Green you are trying to remove? If so, I would soak with diluted bleach to kill it, then and rinse/powerwash it off.
    Essential Links:
    Jan 2014
    Dallas, TX
    69
    Oxyclean and a pressure washer worked great!
    JoyfulNoise's Avatar
    May 2015
    14,093
    Oxyclean is a mixture of sodium percarbonate, sodium carbonate and some perfumes/etc. The percarbonate supplies the peroxide which is a bleaching/oxidizing agent and will definitely kill that moss (chlorine bleach works better). But here's the kicker....it's going to grow back. You need to kill it really good (*cough* *cough* bleach! *cough* *cough*) and then, you need to seal the stone. If you don't seal the stone, the moss will simply grow back again. But, as long as you don't mind the annual cleaning, you can leave it as-is....
    *cough* *cough* ... use bleach .... *cough* *cough* .... dang pollen allergies.....
    Matt
    Jan 2014
    Dallas, TX
    69
    I power washed it too. Next year bleach!
