Results 1 to 8 of 8
Thread: 7 inches of rain in Tulsa, OK - what do i do
    Feb 2017
    Tulsa, OK
    110
    We have been having crazy rain here. This morning my pool was at 3/4" below the skimmer line because I am trying to test for a possible leak.
    I just measured and it is 7" above where it was this morning and about 2 inches from the top of my pool.
    my questions are:
    1. should i let some water out of my poo and if so how much?
    2. this will obviously mess with the chemical balance in my pool, what should i be on the lookout for?
    thanks, i am a new pool owner and dont kniw what to do with all this rain.
    Tulsa, OK,Gunite inground pool - lagoon finish - 20,000 gallons
    Hot tub in one corner that is raised about 3 feet and has two spillovers into the pool
    Small side pool with two pipes that jet up water and has two spillovers into the pool
    Has a sundeck at the front
    Jun 2014
    Rogers, AR
    444
    Re: 7 inches of rain in Tulsa, OK - what do i do
    Quote Originally Posted by tagteamcomputing View Post
    my questions are:
    We have gotten almost four inches today here in NWA. I have dumped water three times today and kept my filter running. I am a little cloudy tonight so I will keep the filter going until it clears. I will test and re-balance everything in the morning.
    It is still coming down like crazy here so other than keeping ahead of the water there isn't much else I can do until it stops.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s300i robot, Raypak 406k Heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Yes, you need to drain water. Enough to leave room for the expected rainfall until you can do it again. If you let the water get to the top of the tiles, it could find its way behind the plaster or loosen grout, maybe even wash out beneath the deck. It's just plain bad all around.
    Whatever percentage you replaced with rainwater, figure you'll have lost about that much FC, CYA, TA, and CH, since rainwater has none of that. pH could go either way, but usually it goes up from aeration from the raindrops pelting the surface. Once the rain is gone, rebalancing should be no big deal, unless you also got massive amounts of debris with the storm.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    I'm in the same boat neighbor!! I drained some water before I left for work this morning around 6am, my husband drained some this afternoon and I drained a bunch more when I got home from work at 7:30. It's STILL RAINING
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Jun 2014
    Rogers, AR
    444
    It looks like the rain is FINALLY moving out for all of us.
    I bought all a bunch of new planters for around the pool and had a bale of professional potting mix that is a couple of years old. It was so dry and hard that I knew it would take a lot to hydrate. I loaded up the planters yesterday in anticipation of the rain and I checked them tonight and they looking good
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    lookout out for any runoff making its way into the pool. Make sure your equipment pad isn't at risk of being submerged, specifically electrical equipment. Its weather protected but not waterproof.
    Any time you have any significant additions of water (from rain or refills) you should run a full panel of tests. You may find that there was no harm done or even helped, but you wont know that until you test.
    You may want to book a room on the closest Ark...
    Good luck
    derek533's Avatar
    Mar 2017
    Edmond, OK
    15
    Here in Edmond, we got about 6". Pool was sparkling yesterday with FC around 6 and today after draining twice which is always fun in the pouring rain, I was down to about 1.5. I had a bag of shock I threw in to get the chlorine back up and I also added about a 1/2 gallon of bleach.
    Now, I'm back to 7 FC, 0 CC, 8.0 PH, TA 200ppm, CH 300, and CYA 55. I figure I'll add about two gallons of acid which should bring the PH down to where I want it and also lower the TA at the same time.
    Don't freak out, just add some chlorine, keep your pump running until the cloudiness is gone, and try not to worry. You're not going to have a green swamp that fast.
    24,000 Gallon In-Ground Plaster
    Pentair DE 48sf Filter
    Hayward Superpump
    Hayward Shark Robot
    Teald024's Avatar
    Aug 2016
    1,488
    Please use PoolMath to determine the proper amount of Chema to add. Guessing won't help you in the long run.
