Results 1 to 8 of 8
Thread: Installing new seal plate, but ran into a problem with motor mount plate
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    I was getting ready to change out my old seal plate and install a new one. Problem is...my motor mount plate threads are corroded away. I was able to get the bolts out, but after soaking/cleaning the threads with CLR, I realized the threads were basically corroded away (see red arrows). I think I can get the bolts through the holes and then threaded into the seal plate, but they won't be threaded through the motor mount holes (just pushed through). What should I do now? I looked around but couldn't fine a replacement motor mount plate plus it looks like I would have to take the whole motor apart to change out that plate. Do you guys think it would hold even the the threads are gone?
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin S200 Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Installing new seal plate, but ran into a problem with motor mount plate
    Is there room to put a nut on the backside? That would be simplest.
    Next up is a helicoil. The hole gets enlarged and rethreaded to a larger size and then an insert goes in, bringing it back to what it was.
    I stand corrected!
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    You don't think it would work if I just got the bolts through the motor mount plate and then threaded them into the seal plate grommets and tightened them up good?
    The backside isn't open. It's enclosed into the seal plate.
    The motor holes were never threaded. You're good.
    Support the site
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by JamesW View Post
    Even better!
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    OK big time blonde moment...I think the bolts are SUPPOSE to slide through the motor plate and then screw into the seal plate grommets.
    Hahaha just realized that...thanks!!!
    Yep, you're good to go.
    Support the site
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    The corrosion had built up inside and when I removed the bolts it left a thread looking pattern...haha! Thanks again guys!
