Thread: Can this be repaired?
    Onslow's Avatar
    Jul 2010
    Kentucky
    147
    Very annoying as the rest of the vacuum head is in perfect shape. Do not want to buy a new one. All the repair parts I see are for the thing that attaches to this.
    Thank you!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Jan 2013
    Long Island, NY
    184
    Re: Can this be repaired?
    If you still have the pieces you can try using fast set epoxy or Gorilla Glue.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    I'd grind off those ears and drill two new holes and make the broken flex handle fit.
    Onslow's Avatar
    Jul 2010
    Kentucky
    147
    Thanks much. Will try that and post back with the results.
