Thread: Getting rid of scale
    asquare's Avatar
    Sep 2016
    Lake Mary, FL
    17
    After following instructions from this forum, my pool is now balanced:
    FC = 6
    CC = 0
    PH = 7.6
    CH = 300
    TA = 80
    CYA = 40
    I travel so I only test my pH once a week. I always adjust to 7.5 but the pH tends to grow to 8.0-8.1 over the week.
    Question 1 = Short of adding Muriatic 2 or 3 times a week, is it ok to get my pH down to 7.3 so that it stays in the [7.3 - 7.8] range? Or is it better to be in the [7.5 - 8.0] range? I assume the former.
    I have a spa that overflows into the pool. The water line goes down slightly when the pool pump is off, leaving a scale line on the tiles (see picture - I took the picture at noon so the actual situation is looking worse than on the picture).
    The situation is stable since my pool got balanced, but I would like to get rid of the scale line. I read the following options
    1) Pumice stone (and elbow grease)
    2) Diluted muriatic acid (1:5 ratio) applied directly to the scale (need to pay attention to the grout)
    3) Lower the pool pH level and brush frequently with stainless steel brush
    4)
    Sequesterant (e.g., from Leslie's pool)
    5) Sanding / grinding (overkill for my situation)
    6) Acid wash (WAY overkill for my situation)
    Question 2 = is the above the right sequence or would you suggest a different sequence?
    Thanks!
    16,600 gallon, midnight blue gunnite in-ground pool with attached spa, Hayward Ecostar 3400VSP variable speed pump, Jandy Aqualink 6100 panel, Blue Haven 450 Filter, HiTec solar panels, Stenner 45MPHP10 connected to Jandy panel for chlorination, Jandy Lite2 Model LJ propane gas heater, Polaris 360, TF Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,303
    Re: Getting rid of scale
    Aim for 7.2 pH and buy a little insurance.
    As a side benefit, the TA will come down some. If the TA is in the 60 range, the pH rise should slow down some, which will buy you even more time between adjustments.
    asquare's Avatar
    Sep 2016
    Lake Mary, FL
    17
    Thanks Richard - what's your perspective on removing the scale line?
    Richard320's Avatar
    Jan 2010
    20,303
    Quote Originally Posted by asquare View Post
    Pumice stone to remove the worst. Adjust pH and TA to drive CSI negative, raise the water level, and be patient.
    asquare's Avatar
    Sep 2016
    Lake Mary, FL
    17
    Will do and will report back in a few weeks - thanks!
