Results 1 to 7 of 7
Thread: New pool construction Quartzscape or Stonescapes
    sbalberti's Avatar
    Apr 2017
    Tyler Texas
    86
    Just about to break ground on a 18X40 rectangle pool. I've never owned a pool, but have been doing a lot of reading. I'm going with a A&A floor cleaning system. Chime in on the pros and cons if you have one of these systems. For the plaster I'd rather spend more up front and have a good product that lasts. I'm OCD so the chemicals will be very well maintained. With that, which lasts longer quartzscapes or stonescapes? My wife wants a bright rich blue water color. Those that have a color similar to a bright blue, can you share a pic of your pool and what color NPT plaster you used. Thanks in adavance for your help!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: New pool construction Quartzscape or Stonescapes
    Hey, Welcome to TFP!
    Pebble finishes are comsidered to be longer lasting than most anything except tile. Now there are thermo-polymers in play as well. Even a very good plaster job can easily last 15 or more years if it has a good life. Quartz will be smoother and cost less than Stonscapes, but it really comes down to personal preference. A well done Quartz or pebble should easily last 20-25 under good conditions. The Blue color you mention is very subjective, so are you thinking light, or dark colored finish? I prefer lighter ones by far, but there is no right or wrong color. So many options. We blended two colors for ours, but It's a different high end brand. The most important thing is getting a good applicator who cares about his work, because the quality of the job is way more important than the brand.
    I'm going to discourage you from the in-floor system and suggest a high quality robot instead. Mind you, we don't hear much about the ones that are running great, but only those that have issues, and we hear it frequently about all of them. Repairs are a real PITA when sprayers get stuck up or down, and they just seem overly problematic. At least for my taste, and a high quality robot cleans more thoroughly anyway. They also don't remove leaves or other debris, so you're left with that as well. Just food for thought, but there will be others weighing in and sharing ideas, and hopefully some colors for you. We are all about tight Chemistry control around here, so you came to the right place for that. Hope you enjoy the forum.
    Cheers!
    Essential Links:
    Aug 2014
    Houston tx
    2,542
    +1 on what Patrick said above - The quality of the job is way more important than the brand.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    sbalberti's Avatar
    Apr 2017
    Tyler Texas
    86
    Thanks for the replies. TNT out of Dallas Tx will be doing the plaster. https://www.facebook.com/TntPlasterConstruction/
    Here's the colors we like.
    18X40 Rectangle Gunite, 27000 gal, Completed 7/01/17 Pentair IntelliFlo 3HP XF. Pentair 3HP Intelliflo booster, Pentair 520 Cartridge, Pentair Easy Touch 8 W/ Screenlogic, A&A In Floor Cleaning System, 3" Suction, 2 - AVSC Debris Removal Main Drains, Waterco Multi-Cyclone Pre Filter, DekChlor auto chlorinator, 4ft Sheer Descent and 2 lighted sun deck Bubblers. 1000 sq ft of decking, TF-100 Test Kit, On City Water.
    Mar 2016
    McKinney, TX
    176
    Have they taken you to see and feel the finishes the have done in person? Some people with quartz complain that they have a very mottled look, while others look perfect. My neighbors quartz looks great, my cousin's pool is splotchy. I think it depends on the application. The stonescapes/pebble finishes, to me, look more even and consistent, but some people think it is too rough. But both should last many years if pool is taken care of properly.
    17K gallon, 18x40, 107 perimeter, 550 sq ft gunite inground pool with raised spa. 3.5 ft. - 5.0 ft. - 4.0 ft depth. Pentair equipment. DE filter. English Walnut travertine paver decking, lueders limestone coping. Wet Edge Primera Stone Sapphire Treasure plaster.
    sbalberti's Avatar
    Apr 2017
    Tyler Texas
    86
    Quote Originally Posted by sham View Post
    Yes, My PB has taken us to a few of their builds to let us feel the texture and see the appearance. We've now decided to go with the Finest Finish Radiant Fusion Micro Pebble. Its got an awesome look and feel!
    Mar 2016
    McKinney, TX
    176
    Quote Originally Posted by sbalberti View Post
    That will be beautiful! Can't wait to see it!
