Thread: VS pump vs one speed worth the $?
    Mar 2017
    Austin, Texas
    47
    I'm sure this has been covered ad nauseam here, but was wondering if we should install a VS pump vs the one speed written in a contract? The contract is for Pentair 1.5 Whisperflo and the cost for a Pentair VS upgrade is $600. We are building a very basic pool, rectangular 14x32 with 6' of that being a sunshelf, so only approx 12K gallons. No spa or water features other than 2 bubblers on the sun shelf.
    Thanks!
    Keri
    Oh, and I'll get a fancy signature when we complete our build .
    Re: VS pump vs one speed worth the $?
    One consideration that isn't mentioned here much is the noise. A VS running at low speed is nearly silent. If your pump is going to be within hearing distance of your pool, I would go for the VS one.
    16 x 32 18,000 gal IG vinyl pool. 1.5HP SuperFlo VS pump. Hayward C4030 425 sq ft cartridge filter. Hotspot FPH heat reclamation pool heater.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Yes, it is worth it. A 1-1/2 hp whisperflow will use about 2000 watts when running. You can run a VS pump at about 1200 rpm for filtering, skimming and making chlorine with the SWG and it will use less than 200 watts.
    I run my VS pump at 1100 rpm and it uses 150 watts. My electricity is 10.25c/kWh and I can run my pump 24x7 for less than 12 bucks per month.
