Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: First test W/ TK 2006
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    FC 4.2
    CC .6
    PH 7.6
    TA 100
    CH 320
    CYA well over 100
    I have been fighting mustard algae for over a year my fault been taking advice from pool store and using 3" pucks. I know im gonna have to drain a good part of my pool off to replace cause of the CYA. My pool is clear for the most part with visible algae that I just brush down. I guess my question is what is the first step after getting the pool refilled I was planning on draining off half my water.
    13k IG Pebble Tec Jandy cartridge Jandy VSP 2hp
    Clear O2 , Ozone UV system
    Circu-pool RJ30+ Polaris 9550
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: First test W/ TK 2006
    You could dilute your pool water 1:1 with tap water and retest for CYA to see if your CYA is even over 200...
    Either way, I'd probably drain more than half. More like 2/3 then refill.
    After fill, recheck your CYA to see where you're at. You may need to do a second drain/fill. No sense doing anything else until your CYA is in a workable range. If it is acceptable, then tackle the pH first, then get some FC in there. Testing your fill water for TA and CH would give you a good idea of where those levels will go on refill.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    30,956
    Yeah, i think the 2/3 drain and refill is a good plan. Then test and see if you have to bring CYA further down with another drain/refill.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Welcome to TFP!
    Pat has you right of course and your best plan is to get that Cya way down before you SLAM. Once you get that done, you are going to enjoy the pool like never before, I promise you.
    Essential Links:
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    I plan on doing the cya test again today before I drain with the dilution test x2 thanks for the quick reply . I just hate having to drain so much water haha
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    CYA 200 I may be draining the whole thing
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    Mine was over 200 as well when I took over from my pool guy. Decided to do a full drain and while I was at it, i acid washed it as well for good measure. Although plaster is old and a bit splotchy in certain areas, the acid wash worked wonders and it now looks really nice after the refill. I also had really high CH levels (1000+). So, I killed three birds with one stone.
    Pool size: 20,000 Gallon Plaster Pool, Pump: Hayward Tristar VS SP3202VSP, Filter: Pentair Clean and Clear Plus 320
    Polaris 280 Pressure side cleaner, Solar cover, Pentair Amerilite LED pool light, Taylor K-2006C test kit
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    My pool is only 3 years old only 1 trouble free season basically is why I'm here now haha
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,153
    Impressive stone throwing. Good job DP.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    So I tried to drain my pool today and figured out my valves for skimmers and main drain aren't installed properly. I should be able to bypass my skimmers and only suck water thru my main drain right ? I just assumed I could do that, not sure, either way once I get the water down to the skimmer line I lose prime. Does this seem right? I can't even verify that my main drain is even sucking unless I hop in the pool tomorrow to check it out.
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    So I drained my pool about 3/4 spent the rest of the filling up only to finally fill it up checked my cya and I'm still about 70-80. My question is how soon should I try to drain some more water and when can i put some chlorine in , my pH is 7.4 TA 100 CH 420 I didn't know my water was hard. Testing again tomorrow in the morning. Should I even bother running the pump all night ?
    40,883
    You running SWG? If not, I would suggest another 1/3-1/2 drain to lower the CYA more. Then start the SLAM process.
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    No SWG at the moment I could see one in my future tho this will be my first season with bleach.
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    ok so I started my first slam and figured out I had made 2 mistakes in the pool math calculator
    1. being I entered 50 cya when I actually have 60
    2. I wasn't aware there was a higher slam level for mustard algae so when I have been slamming at 20 all this time I should've been at 34. im guessing this is a big deal ?
    3. so I performed my OCLT this morning and only lost 2ppm and im still not seeing any CC
    4. CC test when you put the 5 drops in how significant should the color change be ? cause there might be a small hue change, after adding the other drops it never changes to where I feel I just wasted all that reagent
    5. whats my next step should I run my FC level up to 34 ? im at work today so im gonna have to explain all this to my wife so she can do it plus she will have to learn how to do the test for the first time
    as usual any help will be much appreciated
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    577
    Quote Originally Posted by TJSgarlata View Post
    2. You should only do a mustard level shock for 24 hours AFTER normal slam is complete and you are sure that is what you have.
    4. CC test might change color and might not. If it doesn't that is 0 CC and if it does, just depends on how many drops to make clear.
    5. Keep SLAM at regular level for your CYA (I think 24?).
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    2. IF you have mustard algae, you SLAM at the "normal" SLAM level for your CYA, then after you pass the OCLT you hold FC at the mustard algae level for 24 hours. You don't keep FC at that level the entire SLAM. Article: Pool School - Mustard Algae
    3. There is no "normal" or linear expectations to how much CC you will see or what the differences in OCLT from day to day. If you still have visible algae you can skip the OCLT test, unless you are just curios.
    4. If it's a tiny change, just call it 0.5 and don't worry about it too much.
    See 2. I wouldn't try to give your wife too much to bite off, maybe just the FC test and how to use Pool Math to get back to SLAM levels. Drinking from the firehose and all that
    FWIW, only like 1 out of 100 people actually have mustard algae.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    Thanks guys for the help I guess ill raise my FC level up just a bit to get to the correct slam level which wasn't that far off, im guessing I almost passed the OCLT with just losing 2ppm in 8 hours overnight. My pool gets full sun all day with algae growing in the shaded areas on the walls and flat areas so I just figured it was the dreaded mustard algae no algae present now
    So how long should I keep my pool at slam level cause my Labrador is dying to get back in his pool haha
    Jun 2013
    Cerritos, CA
    577
    Until you pass the OCLT... which will include clear and no visible algae dead or alive.
    Christina
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    OK so maybe another 24 hours since I cant do an OCLT till tomorrow morning
  20. Back To Top    #20
    TJSgarlata's Avatar
    Apr 2017
    League City, Texas
    21
    Update after 48hrs of SLAMing so I tested my FC this morning and lost maybe .5 to 1 ppm FC with no CC found. Water looked as clear as I can ever remember and my wife brushed down the sides this morning after I had left to work and didn't find any live or dead algae. So im guessing I had a successful first SLAM Now I should just let my FC back down to 8 and my Lab can start using his pool again. At what FC level is it safe for my lab to get back in ?
